Browno Offline
#1 Posted : Thursday, 10 September 2009 5:32:46 AM(UTC)
Browno
hey all trying to get the headlights and horn working on the xb working pretty sure im getting power to a relay cause i can hear the ticking and where r the fuses located? id also like to no what this bosch thing is looks like it has been cooked
Drive It Like You Stole It......Drive it like you own it
gts308 Offline
#2 Posted : Thursday, 10 September 2009 10:14:07 AM(UTC)
gts308
The little Bosch box next to the battery is a RE55 regulator, that controls your alternator voltage.
"We are but a grain of sand on the beach of life"
Paul351xb Offline
#3 Posted : Friday, 11 September 2009 2:28:13 AM(UTC)
Paul351xb
Factory headlight breaker is clicked in above the fuses. look above drivers side kick panel. Put some relays in mate. Those wires burn real easy. Horn could also be old wires working up a resistence. Also time for a relay. Check your battery and fus
Browno Offline
#4 Posted : Friday, 11 September 2009 4:54:42 AM(UTC)
Browno
hey thanks for this really helps heaps going to have a play tonight :)
Browno Offline
#5 Posted : Thursday, 29 October 2009 3:18:35 AM(UTC)
Browno
g'day all update.... the wiring loom was a mess but im sorting it.
I now have lights that relay u were talking about paul she allready has one i will take a pic and post it. some time in her life it had driving lights fitted some s***ty hazard warning sy
Browno Offline
#6 Posted : Thursday, 29 October 2009 3:20:18 AM(UTC)
Browno
annnd voltage regulator is melted would my alternator need looking at the light doesnt stay on in the dash when shes running
Browno Offline
#7 Posted : Thursday, 29 October 2009 5:12:58 AM(UTC)
Browno
wheres the horn fuse?
Paul351xb Offline
#8 Posted : Thursday, 29 October 2009 8:06:46 PM(UTC)
Paul351xb
Horn fuse is third from the bottom. 16 amp. If the wires have built up resistence it will stop the horns from working. So if the fuse is fine put a relay in at the horns. That's something I've been meaning to get around to for a while now on my car.
crug75hid Offline
#9 Posted : Tuesday, 3 November 2009 6:35:35 AM(UTC)
crug75hid
thats a regulator! its structure says so!
anyways you need to maintain your engine, it needs some oiling at parts
crug75hid
crug75hid
Paul351xb Offline
#10 Posted : Wednesday, 4 November 2009 4:15:35 AM(UTC)
Paul351xb
He's getting there Crug. He hasn't had the car all that long and is slowly bringing the old girl back
into shape.
"Life, a series of events, woven into a tapestry which becomes our destiny"
Browno Offline
#11 Posted : Saturday, 21 November 2009 7:40:56 AM(UTC)
Browno
theres oil where it needs it,
have found out why horn and washers wernt getting any power, wires were pulled from the fuse box.
front blinkers work but rears dont any ideas? bulbs arnt blown,
to do list,
new fuel pump
gasket for the power valve on t
