tripple webers Offline
#1 Posted : Sunday, 20 September 2009 10:52:53 PM(UTC)
tripple webers
Hi there need help, Putting a 460 into a F Series which has a 3 speed Auto C6, is there a 4 speed auto that i can use to replace the C6, which will bolt straight up. Thanks in advance.
gts308 Offline
#2 Posted : Monday, 21 September 2009 10:11:24 AM(UTC)
gts308
A mate of mine fitted a 4 speed auto from a 80's Mustang into his XAGT. Not real sure on the model AOD-4R70W or AOD-4R75W maybe.
The box he fitted was vacuum operated not electronic like the later model AODE boxes. So it was a fairly easy swap.
Hope thi
"We are but a grain of sand on the beach of life"
#3 Posted : Tuesday, 22 September 2009 2:53:45 AM(UTC)
tripple webers
thanks for your reply gts308 are you saying that the 351 cleveland has the same bolt pattern as the 429/460?
gts308 Offline
#4 Posted : Tuesday, 22 September 2009 9:03:41 AM(UTC)
gts308
Im not sure about the bolt pattern...Im sure someone on here could answer that question.
