Relic Offline
#1 Posted : Saturday, 10 October 2009 7:03:10 PM(UTC)
Relic
Hey Guys,
A beginer question what is the best way to locate tdc on a 351 clevo.
I dont belive my timing mark is correct, or the dizzy has been reinstalled wrong, sounds flat and laboured at 10 degree advance.
Any help would be great.
#2 Posted : Sunday, 11 October 2009 2:38:50 AM(UTC)
take the number 1 spark plug out and put a screw driver down the hole and turn the motor over by hand (using the fan and pushing down on the belt) when then screw driver stops going up and starts to going down you are at TDC
Relic Offline
#3 Posted : Sunday, 11 October 2009 4:31:04 AM(UTC)
Relic
Thanks davequey74,
Is there a certain way the dissy should be installed, someone said i might be a tooth out?
Docktor Offline
#4 Posted : Sunday, 11 October 2009 6:32:33 AM(UTC)
Docktor
Dave is right, but his way will give u tdc but a 50/50 chance of being tdc exhaust stroke, best bet is to pull no 1 plug out , jam dunny paper in it and bump the engine on the starter, when the paper shoots out, you are tdc ignition stroke.
Remove the di
Relic Offline
#5 Posted : Sunday, 11 October 2009 7:09:38 PM(UTC)
Relic
Thanks Docktor,
So if its a tooth out either way, is that going to cause me problems?
And would the engine run if it was 180 out?
Docktor Offline
#6 Posted : Monday, 12 October 2009 7:41:16 PM(UTC)
Docktor
It wont physically start and run if its 180 out, it will pop and bang and carry on, if you are a tooth out, it should start but u will find it hard to rev the engine, and will porbably need to keep the revs up around 2K plus , if it runs grab a timing lig
Relic Offline
#7 Posted : Tuesday, 13 October 2009 6:54:05 AM(UTC)
Relic
Thanks for that docktor, I'll give it a try.
What do you think a fairly warm clevelands timing should be?
I have a info card for the scorcher ignition in it, asking for 14 degree, from what ive read seems a bit to much for a clevo.
Docktor Offline
#8 Posted : Tuesday, 13 October 2009 6:39:24 PM(UTC)
Docktor
Is it a reco motor ?. Cam specs ? , head work. is it gunna consistently rev past 6500 ?. for a stockish engine, I would look at around 6 degrees static timing and anything up to 20+on total timing pending on distributor. I am not familar with the scorcher
Relic Offline
#9 Posted : Wednesday, 14 October 2009 6:56:54 AM(UTC)
Relic
Its been built by engine builder, its in a ski boat the info ive got is:
hyperutectic pistons
super moly rings
compression 9.9 to 1
heads 2v ported and flow tested to 470 h.p.
cam crow 21619 on a 109 degree lobe seperation
torker inlet manifold
750
This page was generated in 0.126 seconds.
