WB UTE Offline
#1 Posted : Sunday, 17 January 2010 8:16:08 AM(UTC)
WB UTE
is it a straight forward conversion to put a v8 into an XF panelvan
thanks Ted
Colesy Offline
#2 Posted : Tuesday, 19 January 2010 6:44:05 PM(UTC)
Colesy
Giday mate, it depends on what state u live in and what V8 u want 2 fit. An injected 5L out of a late E series falcon would b the best choise.
#3 Posted : Wednesday, 20 January 2010 2:51:02 AM(UTC)
The XF firewall is different on the passenger side where the heater hoses enter the cabin as there were no V8 XF's made. Some rerouting of the hoses and a hammer are needed otherwise it's a bolt in fit.
Then as Colesy says it depends on your state b
WB UTE Offline
#4 Posted : Friday, 22 January 2010 7:33:06 PM(UTC)
WB UTE
#5 Posted : Friday, 22 January 2010 9:53:27 PM(UTC)
4.1 as a tow engine will be fine as long as you put a decent transmission cooler in it as the Borg Warner auto will be the weak link. Some 6 cylinder XD's had a C4 if you want to replace it with a stronger transmission.
You can also get a cam g
WB UTE Offline
#6 Posted : Friday, 22 January 2010 10:12:42 PM(UTC)
WB UTE
#7 Posted : Monday, 25 January 2010 9:13:07 AM(UTC)
XF's came with two 5 speed boxes.
Early ones were only fitted to 3.3 at the factory because they were basically a Sigma box therefore they were at their limit behind a 3.3 and a 4.1 would have twisted them apart in quick time. They are a cast iron c
