Ned Offline
#1 Posted : Tuesday, 19 January 2010 9:31:37 AM(UTC)
Ned
Can some one tell me if it is common to call the single rails which are behind the 351's t5? I thought all t5 were 5 speed. If so, is there a kit of sorts I can purchase to improve the strength of the single rail? I have a feeling it might not last too long.
#2 Posted : Wednesday, 20 January 2010 2:58:35 AM(UTC)
T5's were all 5 speeders and all alloy casing. 351 single rail boxes had different ratio's and I thing wider (stronger) gear sets than 6cyl and 302 single rail boxes so if you can find a 351 single rail it should be a bit stronger.
Ned Offline
#3 Posted : Wednesday, 20 January 2010 4:47:23 AM(UTC)
Ned
Thanks Jim!
