Adj Offline
#1 Posted : Friday, 29 January 2010 3:45:43 AM(UTC)
Adj
I have a inlet manifold that was on 351 seems slight highrise over oTher manifolds have seen the first no 15b4 I cant Be sure of as hard to read below that is 73da 9425 ab can anyone tell me what it is please
Docktor Offline
#2 Posted : Friday, 29 January 2010 11:32:46 AM(UTC)
Docktor
A pic would help but if its off a 351 it should be a spreadbore manifold pending on year.
Adj Offline
#3 Posted : Saturday, 30 January 2010 5:26:04 AM(UTC)
Adj
How do I post An image cant seem to do it
Docktor Offline
#4 Posted : Sunday, 31 January 2010 1:31:03 AM(UTC)
Docktor
use photobucket and link to it or somethin like that bloke
Paul351xb Offline
#5 Posted : Sunday, 31 January 2010 4:44:38 AM(UTC)
Paul351xb
So is it a spreadbore or a squarebore? 2v or 4v?
"Life, a series of events, woven into a tapestry which becomes our destiny"
Adj Offline
#6 Posted : Sunday, 31 January 2010 4:33:38 PM(UTC)
Adj
The manifold has 4 even holes I dont know what photobucket is would like to post image
Paul351xb Offline
#7 Posted : Monday, 1 February 2010 2:07:13 AM(UTC)
Paul351xb
that's a squarebore. So the manifold is alloy and not cast iron then? Photobucket is a photo hosting site that lets you save photos. You can then put the image here or in other forums. Look it up www.photobucket.com It's free and sometimes a good ide
Adj Offline
#8 Posted : Monday, 1 February 2010 7:42:28 AM(UTC)
Adj
The manifold is defitnaly steel will sort image out In next day or so
Adj Offline
#9 Posted : Wednesday, 3 February 2010 1:23:48 AM(UTC)
Adj
<a href="http://s948.photobucket.com/albums/ad326/allister350/car%20photos/?action=view¤t=351-man.jpg" target="_blank"><img src="http://i948.photobucket.com/albums/ad326/allister350/car%20photos/351-man.jpg" border="0" alt="Photobucket">
Adj Offline
#10 Posted : Wednesday, 3 February 2010 1:33:58 AM(UTC)
Adj
Adj Offline
#11 Posted : Wednesday, 3 February 2010 1:41:26 AM(UTC)
Adj
IMG]http://i948.photobucket.com/albums/ad326/allister350/car%20photos/351-man.jpg[/IMG]
302Superbird Offline
#12 Posted : Wednesday, 3 February 2010 7:09:25 AM(UTC)
302Superbird
Good to see you worked out how to post pics! I hate technology too? What size are the intake ports?
Do you know if it is 2V or 4V?
Paul351xb Offline
#13 Posted : Wednesday, 3 February 2010 8:00:20 AM(UTC)
Paul351xb
http://www.ftrucksaustra...land%20square%20bore.jpg
Does this look the same to you guys? 4V intake photo I found on google.
Adj Offline
#14 Posted : Friday, 5 February 2010 1:10:39 AM(UTC)
Adj
Sorry it took so long but i measured the holes the front ones are 38.25mm the back ones are 41.5mm as for the 2v or 4v i dont really know but the ports are smaller than edelbrock 4v manifold
Adj Offline
#15 Posted : Monday, 8 February 2010 5:19:09 AM(UTC)
Adj
i took photo of manifold from above is different from one in link holes on right side are deeper than left can anyone id what it would b off
JL4049 Offline
#16 Posted : Tuesday, 16 February 2010 9:00:50 AM(UTC)
JL4049
looks like a plain old dual plane, factory cleveland manifold to me, what do the ports measure, height x width at the flange where they meet the head? this will tell you whether it is 2v or 4v.
Adj Offline
#17 Posted : Tuesday, 23 February 2010 12:18:51 AM(UTC)
Adj
sorry took so long but i finally measured a port it was 31.61mm by 47.81mm are these 2v 0r 4v also remembered this manifold takes a holly without an adapter plate i dont think other one i had did is this unusual?
JL4049 Offline
#18 Posted : Tuesday, 23 February 2010 11:28:02 AM(UTC)
JL4049
definately a 2V manifold. The carb pattern is for the autolite 4300 carb found on pre 1976 australian manufactured engines. The manifold is an Australian casting
Adj Offline
#19 Posted : Wednesday, 24 February 2010 2:07:51 AM(UTC)
Adj
cheers for that information that fits in with what i know about engine it came with a 75 p5 ltd 351 cast in usa but probably machined and assembled here according to info from this forum. i had thought it looked different to others i have owned especially
Guest (8)
