Marouk06 Offline
#1 Posted : Monday, 1 February 2010 7:41:43 AM(UTC)
Marouk06
Evening all.
Can anyone confirm that 64-70 mustang front and rear suspension is compatible with the 66-71 falcons?
In particular i'm looking at mustang upper and lower control arms on the front, and a 4 link rear end conversion kit for a 67 mustang.
All my research is looking like it is all bolt in swap work...but before i lay the cash out i'm hoping someone can reassure me i'm right ;-)
Cheers...Phil
#2 Posted : Monday, 1 February 2010 11:50:19 PM(UTC)
RRS could tell you as they make kits for both. I think that they are the same kit for both too.
Vandals and graffiti "artists" do everyone a favour an
STUSXY351 Offline
#3 Posted : Thursday, 11 February 2010 8:07:39 AM(UTC)
STUSXY351
Use Aussie Falcon parts mate. XC Falcon and later use rubber bushed upper control arms. You will need to use the correct lower control arm bushes to suit camber pin diameter. If you use late model up to XF stub axles (better brakes with rotor and caliper
Marouk06 Offline
#4 Posted : Friday, 12 February 2010 2:15:42 AM(UTC)
Marouk06
Thanks Stu,
I've done the conversions you're describing several times, and were certainly happy with the results. I'm just looking for something a little more exotic than std parts this time around. The vehicle is copping a significant amount of custo
