28 Pages«<1112131415>»
the eh Offline
#241 Posted : Thursday, 26 February 2015 2:22:44 AM(UTC)
the eh
The rear end has come out of the EH for a freshen up. New lowered Kings Springs, a set of 3.89 gears to replace the 3.08 and some custom slotting of the rear rotors to match the new 5000 series DBA front setup. The calipers will also be repainted and have new logos applied. I have also done away with the original EH spring insulators and gone to the HQ on commercial setup. This helps lower the car slightly and also helps to keep the diff from walking around as much.
the eh Offline
#242 Posted : Monday, 2 March 2015 5:57:36 AM(UTC)
the eh
the eh Offline
#243 Posted : Monday, 16 March 2015 5:28:59 AM(UTC)
the eh
the eh Offline
#244 Posted : Wednesday, 8 April 2015 11:25:57 PM(UTC)
the eh
EH All State Run 2015 show and Shine..
the eh Offline
#245 Posted : Monday, 20 April 2015 2:00:54 AM(UTC)
the eh
We had a great All State Run and managed to take home a trophy.
the eh Offline
#246 Posted : Monday, 20 April 2015 2:28:59 AM(UTC)
the eh
Machined up some A/C port caps to finish things off
Rebuilt A/C compressor painted up and ready to refit. New braided hoses from Aeroflow help clean up the engine bay.
Dakota Digital Speedo Interface will keep the electronics happy and keep the speedo accurate.
the eh Offline
#247 Posted : Monday, 20 April 2015 2:31:49 AM(UTC)
the eh
The Corvette C6 calipers have been refurbished with new paint and decals.
the eh Offline
#248 Posted : Saturday, 23 May 2015 12:50:17 AM(UTC)
the eh
Chassis kit has arrived. Should have the ute on the rotisserie in a few weeks and this kit fitted.... Progress finally..
the eh Offline
#249 Posted : Tuesday, 2 June 2015 7:23:25 AM(UTC)
the eh
USA made PowerMaster 105amp alternator is for THE EH. This are physically smaller than the Bosch unit and put out 85amps at idle.
Simple adaptor cable to suit Bosch 2 pin connector on the existing harness.
the eh Offline
#250 Posted : Tuesday, 2 June 2015 7:25:01 AM(UTC)
the eh
Under dash brake booster pedal setup is going into the EH ute project..
the eh Offline
#251 Posted : Tuesday, 9 June 2015 6:35:59 AM(UTC)
the eh
We finally managed to get the EH ute project underway. The bare shell is now on the rotisserie and ready for some action.
A couple of dogleg replacements will be needed.
An interesting modification. A bit of old school chassis stiffening.
the eh Offline
#252 Posted : Sunday, 21 June 2015 6:50:49 PM(UTC)
the eh
Some progress on the EH ute project. Fitting the C.R.S. chassis kit subframe reinforcement plates.
the eh Offline
#253 Posted : Friday, 10 July 2015 5:38:25 PM(UTC)
the eh
A bit of progress on the EH ute project
the eh Offline
#254 Posted : Saturday, 11 July 2015 12:43:14 AM(UTC)
the eh
the eh Offline
#255 Posted : Thursday, 23 July 2015 6:26:01 AM(UTC)
the eh
the eh Offline
#256 Posted : Sunday, 2 August 2015 9:16:52 AM(UTC)
the eh
VK Borg Warner modified and ready to go into our EH ute build
the eh Offline
#257 Posted : Sunday, 2 August 2015 9:21:22 AM(UTC)
the eh
XC Barina electric Power Steering column will be going into the EH ute project. An aftermarket controller will make it all work.
Barina steering wheel will give up it's centre to allow me to adapt the EH wheel to it.
the eh Offline
#258 Posted : Tuesday, 25 August 2015 6:52:24 AM(UTC)
the eh
Some work done on the EH ute project. VK Borg Warner diff modified and fitted. VS 8o litre tank fitted and CRS Chassis kit fitted..
[img][/img]
the eh Offline
#259 Posted : Monday, 14 September 2015 7:45:22 AM(UTC)
the eh
The engine went into the ute for the initial mockup. Fitted easily with heaps of room around the gearbox so no floor mods will be needed..
the eh Offline
#260 Posted : Monday, 14 September 2015 7:59:30 AM(UTC)
the eh
Here's some more from yesterdays effort.
Guest (20)
