hammered Offline
#1 Posted : Saturday, 29 August 2015 5:50:07 AM(UTC)
hammered
Is it possible to remove a bung rusted solid in a cylinder head?Not until my old red motor was reassembled did I realise the replacement has a bung in it(passenger side to rear between manifold and rocker cover).I want to fit temperature sender.Otherwise sacrifice having a heater plugged in at front.What makes it so difficult is that it plugs into a water jacket.Probably been in for years.I've tapped it,heated it with propane and used a long socket handle and now is partly rounded.Obviously if it doesn't come out cleanly that could be the end of the head.Anyone have suggestions?
sgo Offline
#2 Posted : Sunday, 30 August 2015 3:01:14 AM(UTC)
sgo
Just a thought, can you drill it out saving the original thread or re threading it??
good luck.
coupe Offline
#3 Posted : Sunday, 30 August 2015 4:36:43 AM(UTC)
coupe
Mig weld a long round bar onto it at least 8 mm in diameter. Use plenty of heat and be quick to undo while theres plenty of heat. Done a few this way and never failed.
hammered Offline
#4 Posted : Monday, 31 August 2015 9:58:58 PM(UTC)
hammered
Even with some shielding around it,could the concentrated heat warp the head?If not think I'll leave it until I take the head off some time down the track.I just have to sacrifice the heater to connect up the water temp circuit.Thanks for your help,that sounds more likely to work than what I tried.
petaus Offline
#5 Posted : Wednesday, 2 September 2015 5:05:09 AM(UTC)
petaus
I would drill through it with an 1/8 cobalt Sutton drill new one, then use I barrel ball die grinder burr down the hole, keep going around with the burr eventually u will break through to the thread most times it will the collapses then wind out, other wise keep going with the die grinder burr till most of the plug is gone then clean up the original thread in the head, as a mechanic I have removed a fare few of others handy work like this.
if your not keen ring around local work shops as most have mobile thread repair guys they use as it a bit of art work to remover broken bolts, studs etc in situ.
when you start removing studs from like Nissan 6 in alloy heads then you have to be real carful the stud crystallise and go rock hard and the burrs and drills will go through alloy like a hot knife through butter, you can do a lot of damage real quick, good luck pete.
hammered Offline
#6 Posted : Thursday, 22 October 2015 1:38:52 PM(UTC)
hammered
You've given me some great options there.Thanks for the help fellas.
