benny Offline
#1 Posted : Tuesday, 2 February 2016 8:33:59 PM(UTC)
benny
I cant find this paint code or trim code anywhere, it is on a hk panelvan Adelaide built body Sydney assembled, paint is 585-0036 and trim is 828-16 0, any help appreciated, thanks guys..
#2 Posted : Tuesday, 2 February 2016 9:12:33 PM(UTC)
828 is an EH colour combination that seems top be Valley Mist Green with a Fowlers Ivory top, but Valley Mist Green is a metallic so should be prefixed by 587 assuming 1968-ish HK.
BUT 585-0036 is a different green which is Hawthorn Green I think, Valley Mist Green should be 587-5098.
However 928 is the colour combination for Hawthorn Green, so check the tag again, it'll be 928.
16 0 isn't a trim code, will most likely be 16A or 16C which is simply green bench seat, the seat material and name changed at HB Torana release hence the code change.
benny Offline
#3 Posted : Tuesday, 2 February 2016 9:26:49 PM(UTC)
benny
yes it might be 928 was hard to read so its gotta be 928-16 c...the c at the end looks like an o to me,but is a bit deteriated so could be c paint is definatly 585-0036, cant find a reference for hawthorn green any where, thanks again..
Edited by user Tuesday, 2 February 2016 9:39:11 PM(UTC)  | Reason: Not specified
