Joined: 25/12/2015(UTC) Posts: 156 ![Australia Australia]() Location: melbourne
I cant find this paint code or trim code anywhere, it is on a hk panelvan Adelaide built body Sydney assembled, paint is 585-0036 and trim is 828-16 0, any help appreciated, thanks guys..
828 is an EH colour combination that seems top be Valley Mist Green with a Fowlers Ivory top, but Valley Mist Green is a metallic so should be prefixed by 587 assuming 1968-ish HK.
BUT 585-0036 is a different green which is Hawthorn Green I think, Valley Mist Green should be 587-5098.
However 928 is the colour combination for Hawthorn Green, so check the tag again, it'll be 928.
16 0 isn't a trim code, will most likely be 16A or 16C which is simply green bench seat, the seat material and name changed at HB Torana release hence the code change. |
yes it might be 928 was hard to read so its gotta be 928-16 c...the c at the end looks like an o to me,but is a bit deteriated so could be c paint is definatly 585-0036, cant find a reference for hawthorn green any where, thanks again.. Edited by user Tuesday, 2 February 2016 9:39:11 PM(UTC)
| Reason: Not specified
