Hi Guys,
Can you please decode this old girls numbers, been in the family since new way back in May 1967 from Preston Motors(Essendon), still has original B & W plates however the original 186 was changed over in 1999 with a HK HPM engine.
Also has the chrome strip like the Prems under the rear window.
Drum brakes, 3 speed crash box & 3.36 banjo diff, Heater/Demister + factory push button radio are all standard items with this HR.
#Large Tag HR 225/160 Body No: 434220 Trim: 878 E57 Insert: 100 Top: 585 9562 D
#Small tag PSN: M117624
#Stampted in firewall HR45205
Cheers guys.....
Thanks: 1 times Was thanked: 629 time(s) in 592 post(s)
Can you send me a picture of the body plate? Is it definitely 100 for the insert code? Do you have paperwork that shows the vehicle details ie mechanical options, and possibly shows the package code? |
I got the above info from the owners hand book + letter from Preston motors & the tags fitted, cant take a pic & post - too hard on this site, However i can confirm the following apon closer inspection:
Insert = 160
Body = HR225MR - 48420M
Stamped on firewall = HR 45205 M
Hope that helps?
Thanks....
Originally Posted by: hkgtsmonaro05  Also has the chrome strip like the Prems under the rear window.
All HR Special sedans have the wide bright moulding under the rear window, It's not exclusive to Premier. It's a reasonable bet that both the heater & the radio are dealer-fitted, not factory-fitted. They are 'factory' items, meaning that they are genuine GM-H/Nasco product, but they are not fitted at the factory. It was possible to order these items from the factory, but the dealer would usually shy away from that, because the extra waiting time could cause the sale to fall over. There would have been plenty of manual Special sedans with drum brakes in dealer stock, so why wait. Get the car in, fit the accessories & the job's done. Dr Terry Edited by user Monday, 14 March 2016 5:41:41 PM(UTC)
| Reason: Spelling |
Originally Posted by: hkgtsmonaro05  I got the above info from the owners hand book + letter from Preston motors & the tags fitted, cant take a pic & post - too hard on this site, However i can confirm the following apon closer inspection:
Insert = 160
Hope that helps?
Thanks.... 160 makes a lot more sense. |
