3 Pages<123>
#21 Posted : Monday, 11 April 2016 12:59:28 PM(UTC)
Originally Posted by: HGV8 Go to Quoted Post
I didn't realise there was a difference in power with earlier and later LX L31's.
Ours from memory was bought in late 1978. Can't remember it's build date though.
Maybe it was one of the later ones...
Regarding the HR 186S 4 speed. They were a lot quicker then a HK GTS Monaro 307 auto between sets of lights.
But then again the 307 powerglide were not much of a performance car.
Jim
There is basically 6 x different red 308's from HT through to the end of HZ/VB:
HT-HQ and early LH. 9:1, small camshaft (253's cam).
L34. Same small camshaft as earlier engines but bigger valve heads, higher compression pistons (9.7:1-ish) and modified intake.
HJ, later LH and early LX. Bigger camshaft (same grind cam as HK GTS327 and HT-HG GTS350), higher compression 9.7:1.
HX and most LX other than A9X. Same cam as HJ, still 9.7:1 but loses significant power in its intake manifold.
HZ and most A9X. Same as HX but different intake.
Later HZ and VB. Compression lowered to 9.4:1.
Power loss of the ADR27A is due to the lean jetting and dizzy setup and the intake manifold has got no restriction as to a stock engine at all.
The early 308's HT-G-Q cam is the same as the 253 of the same year but the HJ 253 on has a smaller cam.
The 308 HJ on, cam is an emission cam with a longer exhaust duration so as to create more heat in the exhaust to burn off more un burnt fuel, the static 9.7:1 was only to bring the same compression ratio as before due to loss of real compression when running due to how the cam works.
The bigger the duration of a cam the higher you static compression has to be, due to the loss of actual compression due to a bigger cam.
The 308 ADR27A cam is the came grind as the Aussie chev cams, is that a fact ?
In order:
Nope. Manifold is the problem, I even have flow bench figures for both that shows how bad the pollution inlet is. Will check but I don't think power jets or even dizzy settings change all that much. GMH de-rated the advertised power of all their engines (except 5.0L) for LX release so when the AD27A engines appeared mid-LX they didn't look as bad on paper as they were. 5.0L dropped from 250hp peak to 216hp peak at ADR27A release.
Nope. HJ engine is the same as HT-HQ.
Nope. It is a performance cam, not an emissions cam. 308/304 carbided engine never got a changed cam after HJ, same general performance cam grind as all hydraulic cam SBC's on the late 60's, early 70's other than the 350/350hp Corvette. It was the cam used in the 327/275 and the 350/295-300.
True, but also depends upon the Octane rating of the fuel you intend to use on it.
Yes (as above).
It's not the 308 HX intake manifold at all as she can make 260 real HP and I have proven it does not make one bit of difference in performance of a stock 308 or even a small 20/60 cam and all the grunt is not at a loss at lower rev's is it.
I could do 5300RPM in top gear with a 3.08 ratio diff and the speedo said 213KM/H in my old HX sandman.
The worst thing for good performance is that the intake manifold flows to well, that you loose lower rev performance.
Mind you with a big cam then such as a large intake flowing manifold would be desirable.
It is the intake, guarantee you. It is the only main difference between HJ and HX engines. Go back and read the Street Machine flow bench article where the figures come from. The pollution manifold is limiting the standard heads, whereas the pre-pollution manifold flows up to 313hp and flows more than the stock heads.
gm5735 Offline
#22 Posted : Monday, 11 April 2016 1:22:29 PM(UTC)
gm5735
L34 Torana now their was no real L34 was there offered to the public and anyroad the big cam came in a box.
As I said, "No particular performance/desirability bias".
I think you're missing the point. If it's outright performance you want then none of the early cars, including the 81837 Monaros, would make the list - some, if not most, of the later Commodores go better, handle better, stop better, are far more comfortable and use far less fuel doing it.
The question was "How would you rank GMH's premium cars?", which is a qualitative question and not a quantitative one.
It isn't "which is faster?"
#23 Posted : Monday, 11 April 2016 1:35:23 PM(UTC)
Where is the VH-K Group 3 ?
It's a bit of a grey area, but HDT & HSV cars are not strictly speaking, Holdens.
Because of their '2nd Tier' manufacturing status, HDT & HSV product are not counted by Vfacts (or any other group) as true Holdens.
However due to FIA Group A regs, the four SS Group A Commodores (VK, 2 x VL & VN) are counted as Holdens, but they were a 'contract build'.
In our list we have to decide if we want to include all of these cars in our thinking. Somebody earlier mentioned the HRT427, again this is not a 'true' Holden.
Edited by user Monday, 11 April 2016 3:30:18 PM(UTC)  | Reason: Spelling
gm5735 Offline
#24 Posted : Monday, 11 April 2016 1:40:22 PM(UTC)
gm5735
Guilty, as charged. It is, however, only there as a special mention, and not in the top ten.
detective Offline
#25 Posted : Monday, 11 April 2016 2:41:18 PM(UTC)
detective
Originally Posted by: gm5735 Go to Quoted Post
Originally Posted by: detective Go to Quoted Post
...It's nice to see we're all a bunch of revheads !! LOL
Perhaps. Where's your list?
...jeeez .. I don't know if i ought to wade in !! LOL....can the VZ CV8-Z auto be considered as a pretty tidy weapon ? I cut my teeth in a HQ GTS 350 Coupe, but the VZ is a better car by a country mile. As for any others I can't say I've had much experience.....
castellan Offline
#26 Posted : Monday, 11 April 2016 3:37:14 PM(UTC)
castellan
Jim
In order:
Yes (as above).
Fact is that if the flow rate can make 313 HP or HX is only 260 HP the standard HQ 308 can only make 196 net HP with twin exhaust.
A mate had a 308 HQ back in 1980 and it had a stock 253 intake manifold and stock 2 barrel carby on it and she went well for only that small carby on it, we would cruse at 180 KM/H and it could do 200 KM/H.
I don't know why it had that setup but that's how he bought it and it had 308 cast on the block.
So you see that even small CFM works well, it does not hinder performance at any rev range until it's compromised, because until she is having to need more CFM due to the rev's need more CFM.
So that being a fact that an engine only need more CFM due to what it needs.
So such will have no bearing at all in the response of performance until it's compromised, so a HX 308 we know does not respond at 1000 RPM 2000 or even 3000 RPM like a HQ does now does it.
The HX 308 It's a dead duck all over, is it not.
And we all know that high air speed in the intake manifold is what makes performance better especially down low in the rev range, so such does no harm to performance as such.
The Bedford truck with the 308 engine has only a 253 intake manifold on it and only a small carby.
The lack of performance of the HX 308 has to be in the jetting mainly.
When I bought my HX back in 1984 the dude who owned it was a mechanic and he pointed out to me about the jetting she must be such a ratio in the Rochester and such in the 650CFM Holley he said for best performance and fuel the Rochester is better than the 650 Holley he pointed out to me.
I have the ratio some where and it's richer than standard HQ not to mention the HX and the Holley has to run at a different ratio to the Rochester to perform at it's best.
castellan Offline
#27 Posted : Monday, 11 April 2016 3:55:51 PM(UTC)
castellan
True the only thing would be is that the HQ 350 and 308 with twin exhaust have much more grunt down low than a Gen 3 5.7L so over 4000RPM the Gen 3 gets cracking.
Sitting on 200 KM/H plus is just so much better in a VT model and on SS Commodore any day.
#28 Posted : Monday, 11 April 2016 5:33:08 PM(UTC)
Jim
In order:
Yes (as above).
The manifold creates the problem as it restricts or upsets air flow at high rpm, the carbs have a slightly different tune on the secondaries probably as the engine is unable to breathe as well as the earlier engine. They appear the same on the primaries. Advance is similar except full cent. advance is a bit higher on the HX engine. HX-HZ engines go well with an Edelbrock Performer which flows near the same as a pre-pollution manifold. Put the dog one back one and the engine is a dog again. Those flow figures are into a perfect port, and they say they were extremely generous to the pollution manifold - fact is the manifold limits the engine, it is designed to slow the air down and make it more turbulent that is why its all ribbed in the plenum. Use the SBC's as an example, the cast iron manifolds are capable of flowing more theoretical hp than the 300hp on the L48 engine, but engines above 300hp they change to an alloy inlet. Put that same alloy inlet on the 300hp engine and it'll produce more hp despite the cast iron manifold capable of more.
Bedford truck 308 had a 4BBL manifold with the same design carb as a 307 HK-HT. It was normal for GM to put 2BBL carbs on their low comp truck engines.
#29 Posted : Monday, 11 April 2016 6:00:57 PM(UTC)
Holden Premium cars is the title.
So the HR 186S option is not on the list, otherwise you could say that a HT Belmont with 308, 4 speed and 3.55LSD on the list. The engine and gearbox option made a reasonable performance vehicle but it is not a muscle car or a premium car as it was a series of options. It could be argued that Holden had an option code for the driveline but if that is the case they also had this for the EH, and therefore every 179 manual EH is a Muscle car like the S4. Thy are not.
if you said what would be a good set of options on a car to make it desirable etc then the 186S 4 speed comes in. You also have to take into account that the test 186S 4 speed had a 3.55 rear axle with 13" wheels. Imagine how well a HK 186S 4 speed with 3.9:1 rear axle on 14" wheels would have gone. The HK GTS had a 3.36 with 14" wheels, to make a performance comparison to the HR you would need a 3.08:1 rear on 13" wheels. Those HRs must have been revving the ring out at 100mph.
HGV8 Offline
#30 Posted : Monday, 11 April 2016 7:05:49 PM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
As can be seen by this road test the HR 186S 4 speed with a 3.36 diff didn't make it to 100mph. I guess one fitted with the 3.55 diff would of struggled to get to 95mph.
I've had a few HR 186S including a 4 speed, they were surprising quick off the mark. Good for getting a jump on some V8's but they eventually would catch up but it would take a while.
j.williams
castellan Offline
#31 Posted : Tuesday, 12 April 2016 9:58:13 AM(UTC)
castellan
My mum had a 186 auto HR with 3.36 diff from new and it did 97MPH flat out, my sister had a 186 auto HK Premier and the HR would blow it away easily, I don't know the top end speed of that HK because the speedo was such rubbish and bounced about to much at top speed to tell.
#32 Posted : Tuesday, 12 April 2016 10:58:49 AM(UTC)
The HK press tests of the day say this too - speedos were useless! They always mention corrected speed - what they did was used a stretch of road with accurately marked intervals and then adjusted their figures later based upon their speedo calibration tests.
castellan Offline
#33 Posted : Tuesday, 12 April 2016 11:21:15 AM(UTC)
castellan
Jim
In order:
Yes (as above).
So that's what that carby is on the Bedford, thanks.
My HX had a HT engine in it when I got it, just a GEM stock reco she only had extractors and twin exhaust but the intake manifold was the same old original HX it came with, old mate had just epoxied up one of the emission ports and tossed it on the pre EGR HT heads, I went out drag racing every week end just about in that HX 1985 to 1986 and never seen any stock 308 out perform it even ones that were worked over, my mate had a full recon engine with a TQ 20 cam in his 308 HJ sandman with same gearing and M21 box, I had it all over him as well even just with 3rd gear runs so it's nothing in it as to skill.
Hell I was neck and neck with a good mates LH Torana 308 with a big 30/70 cam and he had a 3.00 9 inch and M21 box over the 1/4 mile that we had setup out on our cane road that we dragged on, that LH sure went well when I drove it, I was sure it would blow my HX into the weeds, I was so surprised that it could not.
Even a highway patrol cop drove it once and he said f this thing goes, thinking it was Chev powered 350 under it and all it had was a 20/60 cam with stage 3 heads at that time.
No stock 351 XB-C-D-E ever did hose my old pre ARD 27A stock 308 HT engine HX Sandman off and I had plenty of runs and even a mechanic with a small cam in his XC 4SP was to fearful to give the HX a run, he may of just been able but if he lost he would not be able to handle that.
I just dragged out of interest, if I got hosed off did not mean jack to me.
This is why I truly wonder what you are saying about the HX intake, because in my experience it's not true at all.
I would of believed you about the HX intake manifold for sure but I know it's not true for a fact in my experience, hell I owned that van for 20 years and if I thought that manifold was crap I would of tossed it, I even had it welded due to corrosion and put it back on.
If I went to a 25/65 cam I would of went for a HQ type or a 30/70 a Performer manifold, I had seen what the Torquer type did with a 30/70 cam in a mates 308 VB commodore and it was just hopeless.
The engine I got the car with was a early 308 with a HP cast block from a HT Brougham just a GEM recon engine bored out 0.030 now the cam that they regrind the spec to in 1984 who knows what it I truly is, is the same spec as the HT-G-Q or did they do a HJ type spec at the time or do they do their own spec.
I don't think when any company grind a cam that any company can make the same spec as original unless it's under licence to do so, it would be interesting to find out just what GEM, REPCO did and what spec did they do to the red 6 as there are many types that Holden used from EH to HZ.
#34 Posted : Tuesday, 12 April 2016 1:35:06 PM(UTC)
I can't explain your experience, other than maybe was the HX an original 4.2L one with 3.55:1 gearing? That would have made it significantly quicker. You had modified heads and cam in it too, and GEM tended to use one piston for all rebuilds so it could well have been up closer to 10:1 that its original 9:1. If it went that well with the HX manifold swapping to an earlier one would have made it quicker, but exactly what times were you getting? How well sorted were the other cars? An LH with 3:1 gears and an M21 will be pretty slow over the quarter - did it have 14" tyres - would have made it slower again? Did you mate's HJ Sandman have a 3.36 or 3.08 rear end (could be either if an original 308)? I remember in the 80's all the original 6cyl and 4.2L tonners people used to buy with 3.55 or 4.44 rear axles. They'd buy a 308 auto or manual car like a Prem or Statesman or even GTS and put it in the tonner. Those things felt like weapons especially if they were running small tyres like 245/50/14 on the back - it was all in the gearing. Swap the 2.78 or 3.08 gears from the car and the tonner would be a slug.
castellan Offline
#35 Posted : Wednesday, 13 April 2016 4:19:58 PM(UTC)
castellan
My HX XX7 sandman P van was original L31 M21 GV4= 3.36 but he recoed the 3.08 before I got it, I still have the plates for it, 11/1976 build.
I came down to Ipswich willowbank back in 1998 but I had put a trimatic behind it by then and had done 20,000KM on the NGK plugs at the time and she was braking down badly, I was working 7 days a week at the time and just did not get about to doing the plugs and a mates uncle I know was mental about drag racing had said come out to the drags and when I turned up I thought it was the next night but he said no it's today, so out we went and I still have the ticket that says 15.011 sec E.T and speed is 87.39 miles and that was the only time I went to a real drag race track. did not like it much boring to what we did out in the bush where people are much more friendly.
She was just a stock GEM engine then.
That LH had 14in wheels.
Mates HJ van 3.36 or 3.08 but not sure.
I had a LH SLR5000 with 14inch wheels 3.08 LSD diff, in about 1989-90 she had a 650 Holley Double Pumper on it stock motor and it did the same thing at 200KM/H as the HX valve bounce, I put a 2.78 diff in the SLR5000 in the end.
I know plenty who put 308's in the one tonnes, it's the only way to go with them.
From what I have found is never put lower than 3.36 behind a stock 308 or it becomes a shit box that just does not perform and a 3.55 top end would only be 160 KM/H, some dude thrashing about the city might get away with it ok, but in the 1/4 mile I don't think it will out perform a 3.36 or 3.08 ratio.
I would not run 2.78 or 2.60 in a Kingswood size car as it's performance would be crap behind a 308 but a torana the 2.78 was good, now I had 235 T/A tyres on that and at 100KM/H going back to 3rd she would axel hope overtaking flat out, so I gust used top and it passed very well as she had all the grunt in the world and the 2.78 you could use 3rd and hall arse over taking and get better top end speed, I like the 3.08 ratio best and a 3.36 ratio in a torana would not be so good.
The problem with the Toranas is they don't sit as well on the road as the Kingswood size cars can at 200KM/H it's the rear end that gets floating about like and them rear drum brakes are a horror locking up all the time if you hit them hard over 180 KM/H.
I would say the a 3.55 ratio behind a 202 Kingswood is as low as one would go even a 3.36 would be better and anyone who has driven a 4.44 knows such a thing is just total rubbish, a mate had a WB 3.3L 4sp one tonne and he towed the biggest trailer as he was a Builder and he hated that ratio and got a 3.36 put in it and then a Toyota 5sp until I said toss that rubbish away and put a 308 in it and it will be better fuel as well, so he did and a new commodore 5sp box behind it, he was telling his old man that he was getting better fuel economy with the 308 behind it now, his old man had a 3.3L WB one tonner as well and he was convinced old sonny boy was full of it.
Old sonny boy pointed out that the old fella would knot know jack.Applause Angel
Silverfox Offline
#36 Posted : Thursday, 21 April 2016 11:34:38 PM(UTC)
Silverfox
I think it is fair to consider HTD or HSV as acceptable in our thoughts.How about the last of the Monaros? Th CV8-Z beautiful and well sorted. Or the very last of the last of the Australian spec Coupe's, the relatively unknown HSV Signature Coupe' packing the LS2 6litre engine.
Another one to consider is the VH SS Group three with the blueprint package in red of course....loveley car.
307chev Offline
#37 Posted : Friday, 29 April 2016 5:36:59 PM(UTC)
307chev
Was thanked: 2 time(s) in 1 post(s)
Sv89 should be in there too
Simmo Offline
#38 Posted : Thursday, 5 May 2016 1:31:09 PM(UTC)
Simmo
Jim
Back in the early 80's a friend was building lots of performance 308s and he found lots of the HX engines had a different cam chain sprockets that changed the cam timing. I remember him showing me a jig he made to test if engines had the dodgy sprockets.
Anyone else heard of this?
#39 Posted : Thursday, 5 May 2016 3:21:02 PM(UTC)
Yes, to my knowledge the ADR27A V8 camshaft sprocket had its locator retarded by 5 degrees compared to HJ & earlier.
#40 Posted : Thursday, 5 May 2016 8:09:16 PM(UTC)
As far as I can tell the 5.0L timing doesn't change from the start of HJ right through to the end of VL. The 5.0L only ever had 2 x cam sprockets as far as I can tell. HT-HQ 308 was advanced 5deg compared to the 253 (253 sprocket 7434699) but used the same cam (308 sprocket 2808386). When the bigger 5.0L cam was introduced for HJ the 5.0L then used the HT-HQ 253 cam sprocket which was 5deg retarded compared to the HT-HQ 308 cam (basically stood the cam upright).
Not 100% sure what went on with the 4.2L engine from HX through to VB as cam timing changes a few times but the 4.2L does get a new cam sprocket. By XT5 engine release there is only about 2.5deg difference between the 5.0L's cam and the 4.2L cam built into the sprocket and these do appear to be the same gears as used on pollution red V8 engines, so my preliminary guess is there is 3 x different gears in total:
7434699 - 253 HT-HJ, 308 HJ-VL. Let's say "upright" for this one for comparative purposes.
2808386 - 308 HT-HQ. 5deg advanced.
9936255 - 4.2L HX-WB. 2.5deg advanced.
There are some wierdo 92 numbers in early blue parts books but these supersede back to the 1st and 3rd numbers above, hence the lack of 100% certainty.
3 Pages<123>
This page was generated in 0.225 seconds.
