Motorsportlady Offline
#1 Posted : Tuesday, 24 May 2016 4:58:27 PM(UTC)
Motorsportlady
Fitting 23 Spline UC axles to HR banjo housing, Has anyone done this , what issues if any?
Edited by user Tuesday, 24 May 2016 8:13:21 PM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 24 May 2016 5:41:12 PM(UTC)
The bearings are different so either you'll have to modify the axle tube ends or modify the axles to take the tapered bearing. Assuming the length is right. Might be easier to get a LH-LX housing, cut the control arm mounts off and weld the HR ones on. Just make sure you get the right housing for your diff ratio.
This page was generated in 0.017 seconds.
