#1 Posted : Sunday, 15 June 2008 11:59:20 PM(UTC)
Help needed.
Have replaced some instrument cluster background lamps T5 type.
Problem is lights all worked fine with dash fascia out once I'd reassembled the whole dash none of the instrument backgound lights work as well as that the mode switch does not light up either. Everything else works fine, all the warning lights are OK and every other light in the interior works.
Have checked the under dash instrument fuses all OK.
Would like some advice before I pull the fascia off again.
Thank's.
This page was generated in 0.134 seconds.
