307chev Offline
#1 Posted : Thursday, 5 January 2017 2:51:49 PM(UTC)
307chev
Was thanked: 2 time(s) in 1 post(s)
Is the HT 3 speed stronger than the HG onwards box?
#2 Posted : Thursday, 5 January 2017 6:03:29 PM(UTC)
The HT V8 3speed has a higher torque rating according to the HT Engineering documentation. It is a close ratio 3spd. Different input shaft and cluster gear. It is the equivalent of an M21 3spd as in M21 compared to normal Aussie M20.
Edited by user Thursday, 5 January 2017 6:05:25 PM(UTC)  | Reason: Not specified
307chev Offline
#3 Posted : Friday, 6 January 2017 6:23:13 AM(UTC)
307chev
Great
Il put my HT 3 speed in my HG Pano then
Appreciate the help
This is an original 202 Hg too interestingly
#4 Posted : Friday, 6 January 2017 6:41:57 AM(UTC)
It may not be nice to drive though as 1st gear is very short at 2.48:1, it will depend upon your diff ratio and tyre size. Unlike the aussie 4spd though the 3spd has an independent 3rd gear that doesn't have to be the same ratio as 1st, so the 3spd retains its 3.59:1 reverse so at least reverse is OK.
#5 Posted : Friday, 6 January 2017 7:12:37 AM(UTC)
Originally Posted by: 307chev Go to Quoted Post
Great
I think you may have missed the bit about the HT V8 box being slightly stronger. It was only the V8 box that differed, the 6-cyl box was the same. The V8 box has a longer front shaft & is not a bolt-in swap.
One thing though, most of the pre-HQ 3-speeds had a 'smooth' case, whereas the HQ onwards had the ribbed case like a 4-speed. This might be considered 'stronger', even if the gear-set is the same.
307chev Offline
#6 Posted : Friday, 6 January 2017 9:15:37 AM(UTC)
307chev
Ok I see what you guys are saying now
