Ausjacko Offline
#1 Posted : Wednesday, 8 November 2017 8:24:47 PM(UTC)
Ausjacko
H All
Anyone know the static length of the clutch fork to slave cylinder bracket return spring (hook end to hook end)on a hydraulic 4spd set-up in HKTG? I have two and one is a bit too short (90mm) and the other is a bit too long (140mm).
Jacko
#2 Posted : Thursday, 9 November 2017 5:54:57 AM(UTC)
Doesn't answer the question but might help, they are the same part number for the two RHD 4spd manual applications: RH slave on a 307 & 327 and LH slave on HT-HG 350.
If one that you have is too short and the other too long just get one on between!
gm5735 Offline
#3 Posted : Thursday, 9 November 2017 10:13:12 AM(UTC)
gm5735
198mm inside loop to inside loop.
Ausjacko on 9/11/2017(UTC)
Ausjacko Offline
#4 Posted : Thursday, 9 November 2017 9:23:47 PM(UTC)
Ausjacko
cool Geoff, thanks. This must be the 'in between one'.
gm5735 Offline
#5 Posted : Tuesday, 28 November 2017 5:52:01 PM(UTC)
gm5735
Ian, I lied.
The real answer is 75mm, at least with the fabricated clutch slave mounting bracket. Sorry about that.
Ausjacko Offline
#6 Posted : Thursday, 30 November 2017 7:22:03 PM(UTC)
Ausjacko
Stretched the 90mm one and it seems to go OK.
