CrustyHK Offline
#1 Posted : Friday, 8 December 2017 1:17:17 PM(UTC)
CrustyHK
Can anyone tell me if the HJ-WB van upper tailgate fits any earlier vans? Specifically HK-HG
#2 Posted : Friday, 8 December 2017 2:09:39 PM(UTC)
No they won't, they are much taller.
Having side that, I do know that HD/HR/HK/HT/HG van upper tailgates are all the same.
#3 Posted : Friday, 8 December 2017 2:12:22 PM(UTC)
I think the glass is the same but as Dr Terry says they are taller. Extra steel between the glass and the bottom.
#4 Posted : Friday, 8 December 2017 2:23:39 PM(UTC)
Yes, the glass is the same from HD to WB.
Also, a heated rear screen was an option for panel van upper tailgates in the WB series, if you can find one.
#5 Posted : Friday, 8 December 2017 2:27:26 PM(UTC)
So is the roof isn’t it?
#6 Posted : Friday, 8 December 2017 3:35:16 PM(UTC)
Yes the whole turret panel is the same from HD to WB.
#7 Posted : Friday, 8 December 2017 3:37:53 PM(UTC)
The roof is essentially the same HK-HG to HQ-WB, they just added extra steel at the bottom which is why the upper tailgate has extra steel too. The turret was extended as well. When you compare HK-HG part numbers for some of the roof inner bits with WB they are still the same numbers.
CrustyHK Offline
#8 Posted : Friday, 8 December 2017 5:34:37 PM(UTC)
CrustyHK
Thanks gentlemen
