#1 Posted : Tuesday, 14 December 2004 11:13:31 PM(UTC)
Can anyone tell me what size/spec bolts i require to bolt teh torque convertor up to the flywheel on a TH400 to 308??
#2 Posted : Wednesday, 15 December 2004 5:20:18 AM(UTC)
If you have misplaced the originals I believe the bolts are 3/8" UNF with 9/16" AF heads, 3/4" to 1" long. Specify at least grade 8 for both nut and bolt, and use a spring washer of the appropriate size. In a pinch (metric) M10 fine th
This page was generated in 0.141 seconds.
