XX7Q Offline
#1 Posted : Tuesday, 1 May 2018 8:41:43 PM(UTC)
XX7Q
This has most likely been covered before so I apologise in advance but interested in hearing of what steering upgrades are best for early Ford, I have a 66 Mustang rhd with pwr steer which basically steering like a boat, I know their is a lot of after market rack and pinion steering kits some just bolt in have also been told just to upgrade to koni shocks all round and thicker front sway bar, another possible get rid of the power steer?? has anyone done a conversion on the early Mustangs or Falcons etc and can say they got it spot on to the extreme I guest the Rod Tech but I dont think they are a bolt in unit my 66 is a beautiful car its just a shame they dont handle steer that well my 37 Dodge pick up with jag front end is way better.
#2 Posted : Tuesday, 1 May 2018 10:31:32 PM(UTC)
From what I understand most Falcon upgrades are compatible with the Mustang.
Your first idea is probably the cheapest and will probably yield improvements.
From there you can do some RRS upgrades from a rack conversion to a whole front end upgrade.
Then there is the CRS front suspension upgrade which is major work to fit as it does away with the suspension towers completely and also requires a rear drop sump on the engine. They cost around $4500 for the basic kit but can run up from there once you add Willwood brakes and power steering.
 1 user thanked Jim5.0 for this useful post.
XX7Q on 2/05/2018(UTC)
castellan Offline
#3 Posted : Sunday, 6 May 2018 1:06:51 PM(UTC)
castellan
The Power steering has always been totally crap feel on them, just get rid of the P/S and go manual steering there is nothing wrong with the mustang front end at all, it's much like our Aussie old Falcons.
I had a XB Falcon 351 with 265 tires all round and the manual steering was light and had good feel, if you want P/S you can do a XG Falcon type P/S that gives much better feel of the road than the older type.
I seen that kit that does away with the strut towers Jims5.0L said about, be f ed if I could do that with a Falcon let alone with a Mustang and I don't like that kit setup at all because why would you, there is nothing wrong with the spring towers and all setup for handling, it's the steering box that is the only problem with a crappy P/S and manual steering that is to many turns lock to lock that one could complain about.
You need to keep the wheel bearings nipped up well for high speeds.
Like with anything you need it all in good nick and a wheel alignment setup by one who knows how to make them handle, most wheel alignment people will set your frontend up to handle like a boat, this is one of the most important thing you must do to get it right, if you want it to steer and handle well.
Mustangs raced you know and they handled well on the tracks.
Most people do not understand the value in just what can be done with a wheel alignment setup, most think it's about alignment so your tyres do not scrub out, but the fact is it's the geometry that can be setup to make it turn in like a bird dog and will not scrub tyres and will not understeer at all, mine you could not get it to understeer ever, both XB and XG.
Anyone who says that the front end setup is crap is a total fool.
If there is a good rack and pinion setup that bolts up to the original that could be a good thing to do.
 2 users thanked castellan for this useful post.
darrenreadd on 13/05/2018(UTC), XX7Q on 12/06/2018(UTC)
XX7Q Offline
#4 Posted : Wednesday, 13 June 2018 1:07:57 PM(UTC)
XX7Q
Their are a few aftermarket rack and pinion steering kits but have heard conflicting reports on most, think I would prefer to try the conversion to manual steering box first up and see what difference that makes and maybe a thicker front sway bar which I am told helps with the handling side of things. Interesting you mentioned the racing side of things cause I have seen that and thought that myself with I think Bob Jane and the Geoghan Bros Norm Beechey etc and thought surely not with how mine handles lol like a boat
