#1 Posted : Thursday, 16 December 2004 7:38:28 PM(UTC)
Hi everyone, I slotted in a supra box into the ek and need some help with the clutch setup. It uses a Dellow housing and the original hydraulic slave, fork and push rod. I have mounted the slave cylinder using a holden bracket, but the slave seems to be too close in to the bellhousing. This means the push rod is on an angle outwards to mate up to the hole in the fork. I was wondering if I could use the other hole on the fork for the pushrod(closer in to the housing) to mate up to the slave cylinder. (drill it out to make larger). Or would this put too much pressure on the slave/pushrod by loosing leverage?
Anyone have any ideas?
