HK1837 Online
#1 Posted : Friday, 1 August 2008 4:32:47 AM(UTC)
Terry, Warren, others?
Saw an original stamped J72 cast 4 speed pattern 308 today, with the engine number 308N351xS.
Ive heard of 186NxxxxS before and assumed it was a Nasco replacement 186S but the 308 number may now throw a spanner into this. Dr Terry and I talked about this a while back and assumed the above number might be a Nasco 186S, and surmised that others might be 161Nxxxx (no need for L or H as difference is in head), 186NxxxxL, 186xxxxP, 253xxxxL and 253xxxxH. The 308NxxxxS sort of muddies this a lot. Suggestions??
Obviously the 308 is a Nasco engine for a HT/G, but what does the S mean? Short? When I got told about it I assumed it was a 5 not an S but it's definitely an S. Could it mean South Africa?
It makes sense that Holden would have supplied a 308 in 1972 for a HT/G using a 1972 cast block. What would they have done for a 186? Would they have stockpiled them or built one using a 202 block with a 173 crank?
Edited by user Friday, 1 August 2008 7:02:15 AM(UTC)  | Reason: Not specified
HK1837 Online
#2 Posted : Friday, 1 August 2008 5:25:04 PM(UTC)
Have just been suggested S = service??
