#1 Posted : Tuesday, 21 December 2004 6:52:35 AM(UTC)
Can anybody advise which way the fan fitted on the front of the Air Conditioner radiator in front of the main radiator in a VK should turn.I have just replaced the original unit and the wires can be input either way which causes the fan to run anti clockwise one way and clockwise if the wires are swapped
#2 Posted : Tuesday, 21 December 2004 8:11:16 AM(UTC)
Just make sure that it is sucking air into the radiator, you can feel this by putting your hand near it when it's running. If you feel air blowing out towards the front of the car then it's connected in reverse.
Peter
#3 Posted : Sunday, 26 December 2004 5:49:19 AM(UTC)
Thanks for the info Peter
Ken
