#1 Posted : Monday, 25 August 2008 7:36:02 PM(UTC)
Can anyone tell me what the spark plug gap should be for a WB 4.2ltr 253 V8?
Also, I am unsure if I should rebuild the engine, I have taken the engine out of the ute to clean it up. The engine was running really well and was on dual fuel, however I am going back to just petrol, I am going to change the dizzy out for a new one, new leads, plugs and check gaskets,check welch plugs, check water pump. Should i go to the extreme of a rebuild or is there other things i should just check and replace i.e timing chain?
Appreciate your time and advice.
