benny Offline
#1 Posted : Friday, 3 September 2021 12:42:34 PM(UTC)
benny
hi everyone, wanting to know if someone can help me just reassembling my hk monaro first series no. 55 adelaide build if it would have an offset booster or just a later straight type and if there should be a dent in the inner guard of the K -frame or not to clear the booster,, thanks in advance..
#2 Posted : Friday, 3 September 2021 1:35:44 PM(UTC)
If it’s the 55th Elizabeth bodied Monaro then that would be probably a June 1968 assembly so would definitely have a straight inner guard behind the headlight and an offset booster probably without the dent. If it’s the 55th GTS that is a fair bit later so may have the dent for the booster but probably still an offset booster. If it’s the 55th GTS327 that is heaps later.
benny Offline
#3 Posted : Friday, 3 September 2021 2:43:42 PM(UTC)
benny
it is a 327 car if that makes a difference,,i should have made that a bit clearer, thanks
#4 Posted : Friday, 3 September 2021 4:44:00 PM(UTC)
That is a reasonable time after initial build, remember Elizabeth built less cars than both Pagewood and Dandenong. To get the right answer though on lever versus straight brake booster you really need to find a reasonably original car close to your build number to see what it has. Ben and Warren stated in their book that sometime in September 1968 was when the straight rod type booster began to be installed.
benny Offline
#5 Posted : Friday, 3 September 2021 4:52:04 PM(UTC)
benny
ok thankyou you are a wealth of information..
