holden05 Offline
#1 Posted : Friday, 24 September 2021 8:29:18 PM(UTC)
holden05
Whats the coolant capacity of this vehicle with a 3 core radiator and what’s the best ratio to mix coolant
#2 Posted : Friday, 24 September 2021 9:40:14 PM(UTC)
I wouldn’t run coolant unless temperature extremes demand it. Just run corrosion inhibitor. Nulon sell one that is Aussie made. Bottle tells you the ratio.
#3 Posted : Friday, 24 September 2021 9:43:38 PM(UTC)
capacity?... with/without heater and or aircon system? differs you see
and ratio..??? whatever the brand says on the bottle or do what the factory did
water with an inhibitor pill (for anti corrosion)
