gmholdman Offline
#1 Posted : Thursday, 25 September 2008 2:07:00 AM(UTC)
gmholdman
Can oxygen sensors be tested out of the vehicle or do they have stay connected and tested with Tech 1-2 ?? AL.
#2 Posted : Thursday, 25 September 2008 2:35:38 AM(UTC)
Hi AL.
They have to be tested in the car, but you dont necessarily need a scanner. A scanner is the easy way, but if you dont have one, most workshops use a multi-meter (or similar) that has a bar graph type display. Once the sensor is warmed up & work
Edited by user Thursday, 25 September 2008 2:51:20 AM(UTC)  | Reason: Not specified
Blue ballz Offline
#3 Posted : Thursday, 25 September 2008 6:22:46 AM(UTC)
Blue ballz
Do they show as a fault on the engine light or anything if they are faulty?
gmholdman Offline
#4 Posted : Thursday, 25 September 2008 8:47:52 AM(UTC)
gmholdman
Thanks Dr...will start with earth search. AL.
#5 Posted : Thursday, 25 September 2008 5:58:36 PM(UTC)
