Fastlane
Holden Forums
Holden General Discussion
Is this a base model monaro 4 door ??
Joined: 21/05/2022(UTC) Posts: 2 ![Australia Australia]() Location: brisbane
Hi All new to this great forum
was hoping i could get help in identifying this HQ Sedan Tags are
tag 1
MODEL 80469QR BODY No 780059-S TRIM 1821 - 30E PAINT 56813134
ENG L31 TRANS M21 AXLE GV (8 or 2) ?? cant read easily
tag 2
HQ SEDAN 8/73 DHQ85618S SEATING CAP 5
tag 3
8N69TCH780059Q
CHASSIS RAIL STAMPED CHQ45598S
BODY FIREWALL STAMP 85632S
cheers Anthony
Thanks: 1 times Was thanked: 607 time(s) in 574 post(s)
There is no such thing as a base model Monaro 4 door. The sedan versions were only ever GTS models and were initially a special vehicle package code XV4 on a HQ Kingswood sedan. Then from HJ-HX they were plated as a Monaro GTS sedan and just GTS sedan for HZ.
That car listed above is an L31 optioned Kingswood sedan, it isn't an XV4. If it was an XV4 it'd have 30X or 30Y trim not 30E. What it is, is someone wanted a 308 powered HQ sedan and probably was smart enough to realise that optioning L31 (308) on a HQ V8 Kingswood sedan was far cheaper to insure than any XV4. I wouldn't be surprised if it also had U21 dash and N66 rally rims. It had no other mechanical options other than L31, so it was bog standard mechanically other than the 308 engine optioned over the standard 253. The BODY tag read L31 M21 GV2 (308, 4spd and 3.36 rear axle).
It was sold by possibly Commonwealth Motors in the ACT but you'd need confirmation on that. |
Thanks very much HK1837 yes it does have U21 dash Greatly appreciated Anthony Edited by user Monday, 23 May 2022 9:32:40 AM(UTC)
| Reason: Not specified
Fastlane
Holden Forums
