SBozza Offline
#1 Posted : Friday, 23 December 2022 2:14:51 PM(UTC)
SBozza
Hi all, i've got a master cylinder on my HK 327 second type from Pagewood and its shape is the same commonly used on LJ GTRs and Xu1's -squarish top. Most if not all of the master cylinders i've seen on HK v8 Monaros are the oval shape type. Now the casting date codes on the bignut and body of my master cylinder are 20E7 and 16E7 respectively. I know the second type 327s were a bitza engine and there was a shortage of parts and my question is could my master cylinder be off a Parisienne or Impala that were being built around the same time?
#2 Posted : Friday, 23 December 2022 3:08:07 PM(UTC)
The "squarish" m/cyl did not come into production until mid-1971 (HQ). Your car left the factory with the 'rounder" version.
The dates could be 1977.
SBozza on 23/12/2022(UTC)
SBozza Offline
#3 Posted : Friday, 23 December 2022 3:58:44 PM(UTC)
SBozza
That was my first thought as well. Mine has DiSC stamped as well as the date code on the Bignut. On the body there's the date code and some other code that I can't make out, although it doesn't seem to be 'Holden' stamped. All of the 1977 master cylinders I've looked at have a different lid (pitched roof type) and have FRT WHL DISC stamped on the bignut and 'Holden' stamped on the body hence my doubt and uncertaiunty.
#4 Posted : Friday, 23 December 2022 4:21:03 PM(UTC)
No chance of it being from a GMH Pontiac or Impala as it wouldn't work - both of those were boosted drum brakes.
SBozza Offline
#5 Posted : Friday, 23 December 2022 5:12:33 PM(UTC)
SBozza
I thought HK1837 would know the answer to my question considering the research he's done on the equivalent GM vehicles. Appreciate the reply Dr Terry and HK1837
I managed to get sometime ago the correct type master cylinder but it needs restoration. Any recommendations around Sydney area?
#6 Posted : Friday, 23 December 2022 5:39:21 PM(UTC)
Dr Terry did or used to do them. He still has to do my HJ's original cylinder!
8D11PCH2 Offline
#7 Posted : Saturday, 24 December 2022 7:20:27 AM(UTC)
8D11PCH2
For a HQ type master cyl to have 20E7 & 16E7 (May 1977) date codes it would have come from the GMP&A spare parts bin.
Edited by user Saturday, 24 December 2022 7:22:53 AM(UTC)  | Reason: Not specified
#8 Posted : Saturday, 24 December 2022 8:37:33 AM(UTC)
Does the nut off a HX cylinder fit on an older cylinder? Doesn' explain the body though. You'd expect that in mid 1977 you'd still be able to buy new spare part cylinders for HQ and HJ though.
8D11PCH2 Offline
#9 Posted : Saturday, 24 December 2022 8:47:56 AM(UTC)
8D11PCH2
I expect the nut would be the same size and thread. GMH used the HQ type m/cyl in HX production up to the end of or near the end of 1976 so GMP&A replacement m/cyls would have been made and available for many years to come.
SBozza Offline
#10 Posted : Tuesday, 10 January 2023 8:03:23 AM(UTC)
SBozza
Did all factory HK 327 Monaros come out with a big nut on the master cylinder? I have seen a few (mostly type one) without the big nut.
#11 Posted : Tuesday, 10 January 2023 9:59:00 AM(UTC)
I think there was only maybe 3 master cyls in HK. Drum, disc and that wierdo A/C one with one of the brake pipes out the front, it might have been drum only as you couldn’t get A/C with discs and V8 early on in HK. In short GTS327 won’t be any different to other disc brake HK at the same time.
SBozza on 10/01/2023(UTC)
#12 Posted : Thursday, 12 January 2023 9:35:20 AM(UTC)
During early HK production, they imported some Delco Moraine m/cyls from the US to supplement local production. These were basically the same except they had no 'Big Nut', however they were well & truly all used up before any Monaro builds.
The m/cyl with the brake pipe exiting the front was their first attempt at fixing the problem of fitting a/cond combined with a V8 engine & disc brakes. The issue was that the m/cyl pipe fouled the compressor.
The eventual fix was the used the 'straight' style booster which mounts closer the inner guard, allowing more clearance for the compressor.
Edited by user Thursday, 12 January 2023 9:46:22 AM(UTC)  | Reason: Spelling
SBozza on 12/01/2023(UTC)
#13 Posted : Thursday, 12 January 2023 5:36:54 PM(UTC)
That makes sense Terry. Drums and boosted drums (with the smaller booster) wouldn't have had the same clearance issue as a disc brake car did with the big Harrison compressor. Thinking back the only car I can clearly recall seeing was a Monaro coupe in Mako Blue (probably 1-2 weeks pre GTS). It was air, steer V8 and had that weird master cylinder on it. It was some sort of dealer display car as it had just about every GMH or Nasco option you could throw at a Monaro. It was fitted with the GTS's wheel covers probably before any production GTS was assembled. Possibly only the three Elizabeth GTS offline pilots (two 186S and one L34 optioned) and one online pilot each from Dandenong, Elizabeth, Acacia Ridge, Pagewood and Mosman Park (all V8 (307)) were built prior to it.
#14 Posted : Sunday, 15 January 2023 9:36:55 AM(UTC)
Technically they were 'Sports Wheel Discs' & were available in HK Day 1 (Jan 68) on Kingswood & Premier etc.
#15 Posted : Sunday, 15 January 2023 10:39:54 AM(UTC)
Yes I know. What I was getting at though that the Monaro I was talking had them before almost any GTS did.
#16 Posted : Monday, 16 January 2023 5:45:17 PM(UTC)
Did it have a GTS dash?? Whistle
#17 Posted : Monday, 16 January 2023 5:48:05 PM(UTC)
No, it had the U21 option dash, ie 120mph speedo with the sports instruments.
This page was generated in 0.123 seconds.
