holden05 Offline
#1 Posted : Sunday, 3 December 2023 9:29:00 PM(UTC)
holden05
I’m trying to id the dash in the wb ute
It’s a gts style with a woodgrain fascia and yellow needles
I’ve been told it’s a hz premier dash
Would this be correct?
#2 Posted : Monday, 4 December 2023 5:55:31 AM(UTC)
Yellow needles is WB or HZ. Woodgrain fascia could be later HJ to HZ Premier or later HJ LS or HZ SL/E or HX LE. The SL/E and LE have a burr walnut finish. It is possible the sports instruments are original to the WB and it has had the fascia replaced, or they could be out of another HZ or WB. Does the fascia have an RTS badge on it?
holden05 Offline
#3 Posted : Monday, 4 December 2023 7:57:59 AM(UTC)
holden05
yes it does
#4 Posted : Monday, 4 December 2023 10:12:55 AM(UTC)
Means HZ, so it’s either HZ Premier or HZ SL/E. They are different wood grain to each other.
holden05 Offline
#5 Posted : Tuesday, 5 December 2023 1:36:01 PM(UTC)
holden05
yep. looks like its a hz premier. does anyone have a wiring diagram for this?
Chris W Offline
#6 Posted : Tuesday, 5 December 2023 6:51:09 PM(UTC)
Chris W
I do. Can I email it to you?
holden05 Offline
#7 Posted : Tuesday, 5 December 2023 7:23:04 PM(UTC)
holden05
Yes thanks
[email protected]
