Guest77 Offline
#1 Posted : Sunday, 30 June 2024 11:00:12 AM(UTC)
Guest77
[img]null[/img]Need help identifying air cleaner housings as one has 2 side holds in total one square for breath hose filter and one for the heat sensitive vacuum switch the other has 3 in total an extra round hole or has this just been modified
I don't seem to be able to add pictures
Edited by user Monday, 1 July 2024 3:25:43 PM(UTC)  | Reason: up date
#2 Posted : Sunday, 30 June 2024 11:20:45 AM(UTC)
There is at least a dozen different HT to VL 308/5.0L air cleaners. I can’t tell from the descriptions given. Photos are hard here, have to use a hosting site.
Guest77 Offline
#3 Posted : Sunday, 30 June 2024 11:53:24 AM(UTC)
Guest77
The one with the 2 holes and Heat sensitive vacuum switch has a notch for the switch and approx 200mm from the breater filter hole the other has the square hole and 2 larger round holes at 30mm and are about 100mm from the square hole and then 100mm apart. Both Have The Preheat on the Snorkel please see pics
Edited by user Monday, 1 July 2024 3:28:07 PM(UTC)  | Reason: Added Pics
#4 Posted : Monday, 1 July 2024 8:37:11 AM(UTC)
Need photos. They are working again.
Create an album under your profile and upload images. The number the “full site” (not mobile app) edit your post and there is an “add album image” button.
Guest77 on 1/07/2024(UTC)
