Fastlane
Holden Forums
Holden General Discussion
holden 308 rochester 4 barrel air cleaners
Joined: 20/04/2012(UTC) Posts: 2  ![Australia Australia]() Thanks: 1 times
[img]null[/img]Need help identifying air cleaner housings as one has 2 side holds in total one square for breath hose filter and one for the heat sensitive vacuum switch the other has 3 in total an extra round hole or has this just been modified I don't seem to be able to add pictures    Edited by user Monday, 1 July 2024 3:25:43 PM(UTC)
| Reason: up date
There is at least a dozen different HT to VL 308/5.0L air cleaners. I can’t tell from the descriptions given. Photos are hard here, have to use a hosting site. |
The one with the 2 holes and Heat sensitive vacuum switch has a notch for the switch and approx 200mm from the breater filter hole the other has the square hole and 2 larger round holes at 30mm and are about 100mm from the square hole and then 100mm apart. Both Have The Preheat on the Snorkel please see pics    Edited by user Monday, 1 July 2024 3:28:07 PM(UTC)
| Reason: Added Pics
Need photos. They are working again.
Create an album under your profile and upload images. The number the “full site” (not mobile app) edit your post and there is an “add album image” button. |
Fastlane
Holden Forums
