#1 Posted : Monday, 12 July 2004 9:01:10 AM(UTC)
Hi all, I've swapped coils as suggested by Jim but unfortunately this didn't work. I have renewed the leads, rotor,distributor cap but there is no spark at the plug when tested. I ran a diagnostic test with my multimeter and the code appeared to point to a faulty distributor. Would a faulty TFI module appear as this code? Any advise would be appreciated.
#2 Posted : Thursday, 15 July 2004 12:39:04 AM(UTC)
The TFI is a common fault in all Fords. Before this check that you are getting 12V to the TFI. Check the fault code listings however I suggest that you change the TFI it is inexpensive around $60 be sure to apply the white heat sink paste to the back and
#3 Posted : Friday, 16 July 2004 7:59:18 AM(UTC)
Thanks George, It was the TFI module in conjuntion with a faulty pickup inside the distributor. All in all an exercise i hope not to repeat in a hurry. Cheers
#4 Posted : Friday, 16 July 2004 7:59:50 AM(UTC)
This page was generated in 0.083 seconds.
