holden05 Offline
#1 Posted : Monday, 29 July 2024 7:53:53 PM(UTC)
holden05
Back to work on the vc
What’s the best way to remove the radiator trim panel
I know these are hard to get so didn’t want to destroy it
I’m assuming this needs to be removed for the rad to come out
Edited by user Monday, 29 July 2024 7:54:44 PM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 30 July 2024 10:31:56 AM(UTC)
you talking the black plastic panel that sits on the top rad support panel?
and covers the gap between the pnale and radiator?
Its held on by 4 push in plastic trim clips. Remove with a trim remover or screw driver
If you are talking the radiator fan shroud, its got 2 screws at the top and 2 lugs
at bottom taht sit in radiator clips. remove the screws and pull this up
(after removing the engine fan if a clutch fan)
HTH
