#1 Posted : Friday, 7 January 2005 4:14:10 AM(UTC)
is the ECU in a camira identical to the one in a VN commodore (besides tune/setup)
for example, will a VN V8 loom plug into the camira ECU
#2 Posted : Friday, 7 January 2005 5:03:34 PM(UTC)
Hi Guys.
There are 2 types of Camira Delco EFI systems. The JD 1.8 ltr TBI & the JE 2.0 ltr MPI.
The JE 2.0 uses the same 1227808 Delco ECU as VN/VQ/VG/VP (& VL Walkinshaw) but the JD is a different unit that doesn't use an oxygen sens
#3 Posted : Friday, 7 January 2005 8:27:34 PM(UTC)
thanks alot Dr. Terry
