holden05 Offline
#1 Posted : Saturday, 19 October 2024 7:40:16 PM(UTC)
holden05
Ive overhauled the master cyl on the vc commodore and bled the brakes but feel I still have air in the system
How many pumps of the pedal would it take to move fluid from the outlet of the master cyl to the brake caliper?
greenhj Offline
#2 Posted : Saturday, 19 October 2024 9:43:12 PM(UTC)
greenhj
Well, you could calculate displaced volume per stroke of the master and work out the volume of the lines to decide how many pumps, or just bleed it again and see if it improves.
If youve pinched/damaged a seal in the master then you're losing pressure and nothing will change.
#3 Posted : Sunday, 20 October 2024 8:39:50 AM(UTC)
you did fit the new seals the right way?
ps... LOTS of pumps from master to LHR caliper, only 2 or so to RHF caliper
holden05 Offline
#4 Posted : Monday, 21 October 2024 4:35:27 PM(UTC)
holden05
For the LHR how many pedal pumps would be right if I had air at the master outlet?
Edited by user Monday, 21 October 2024 7:07:23 PM(UTC)  | Reason: Not specified
stevo Offline
#5 Posted : Tuesday, 22 October 2024 3:02:59 PM(UTC)
stevo
if you cant graverty bleed it then 3 or 4 goes at each bleeder nipple there is something wrong as in air leaking in some where.
open the nipple till fliud comes out do that on all nipples, then bleed it with a helper pump up pedal open nipple. I once lost the reaction disk in the booster and changed 1/2 a dozen master cyclinders before I worked out what was wrong.
GM bleed us dry and run away.
