TonyMax Offline
#1 Posted : Thursday, 10 April 2025 2:43:53 PM(UTC)
TonyMax
I need one of these ducts for rego to get air onto my windscreen, but I looked under the dash of 4 or 5 cars at the wreckers yesterday and they all seemed to be slightly different where they join into the rest of the system.
Is this something Holden did just to mess with us?
The rest of my system is all solid with no flex piping, see other photo.
#2 Posted : Thursday, 10 April 2025 4:41:36 PM(UTC)
Was thanked: 235 time(s) in 209 post(s)
does your car have factory a/cond ? They're different. Also there is another version with 2 flexible tubes going to the centre face vents.
TonyMax Offline
#3 Posted : Thursday, 10 April 2025 6:42:08 PM(UTC)
TonyMax
I don't have or want AC. I just need to be able to get air to blow on the screen to pass rego.
greenhj Offline
#4 Posted : Friday, 11 April 2025 7:37:01 AM(UTC)
greenhj
Was thanked: 15 time(s) in 13 post(s)
Does it need to be warm air to pass inspection?
Is the original fan/heater core assembly still in the car?
TonyMax Offline
#5 Posted : Friday, 11 April 2025 12:20:55 PM(UTC)
TonyMax
It doesn't need to be warm which allows me to do heater plumbing at a later date. There's a heater core in the car.
I believe I need the y shaped windscreen duct that fits on the right hand flap/opening in my heater box:
#6 Posted : Saturday, 12 April 2025 10:48:38 AM(UTC)
As Dr Terry said, there are at least three, factory AC, cars with no centre face level vents and cars with centre face level vents.
What is your car fitted with?
TonyMax Offline
#7 Posted : Tuesday, 20 May 2025 10:08:47 AM(UTC)
TonyMax
Got one, got it fitted and passed rego. Yay.
I also hooked up my heater hoses and have warm air now, but to truly warm up the cabin I need to fit the big round duct that goes from plenum to greater box.
Does this need sealant or just the foam strip around? Also should the fan have sealant applied where it mounts to the heater box?
greenhj Offline
#8 Posted : Tuesday, 20 May 2025 10:25:58 AM(UTC)
greenhj
Not sure what was used from factory and it's been a while since I pulled it all out of my car but since its only air I would use a closed cell foam rather than sealant.
Clark rubber is usually my goto for random sealing jobs.
#9 Posted : Tuesday, 20 May 2025 8:38:03 PM(UTC)
You can buy the foam seals on eBay or rare spares. They were not glued.
TonyMax Offline
#10 Posted : Saturday, 24 May 2025 4:39:44 PM(UTC)
TonyMax
Ok so my next question about vents is I've put the plenum to heater box duct in today, but the butterfly doesn't go to a position that blocks air from coming in from the plenum.
It will block the passage do that the heater box draws solely from the plenum but doesn't block off so that we effectively have recirculate sure as you can have in newer vehicles.
It's getting colder down here so I want to rig it up so that we're as warm as possible in the mornings, do I have to fabricate block off plates myself?
I'm not fully up with how all the cables work, and it doesn't help that my car is a hybrid of HJ, HX and HZ parts.
This is what I have fitted today:
#11 Posted : Saturday, 24 May 2025 4:55:25 PM(UTC)
You have to have airflow over the heater core for the heater to work. If you block off the plenum opening you won’t get any hot air out of your vents at all.
#12 Posted : Saturday, 24 May 2025 4:56:38 PM(UTC)
The cable only lets air go down to your feet.
TonyMax Offline
#13 Posted : Saturday, 24 May 2025 6:56:40 PM(UTC)
TonyMax
The fan blows air through the heater box over the core. I just want that air to be all drawn from in the cabin not straight from the plenum. That duct also has the weird outlet to the front against the glove box.
