Wallsy Offline
#1 Posted : Friday, 23 May 2025 7:00:39 PM(UTC)
Wallsy
Recently purchased a HK GTS and would like to narrow down the build date.
I have VIN and body tag, but the whole front end has been changed at some point, so other dates stamped on those parts don't match.
body - 30780737KR-00xxx-H5
Stamped on the firewall - HK25401 S(?)
Any help appreciated
HK1837 Online
#2 Posted : Friday, 23 May 2025 8:13:29 PM(UTC)
Chassis number will be HK25401SS.
I can’t tell you anything with numbers omitted. There is a 900 car gap between Pagewood GTS 00100 and 00999. Although I suspect your car might be 00380 or 00381.
Wallsy Offline
#3 Posted : Friday, 23 May 2025 8:52:07 PM(UTC)
Wallsy
You're right - 381
Do you have any info on the dates (Rough month?), location of build etc?
HK1837 Online
#4 Posted : Saturday, 24 May 2025 7:22:33 AM(UTC)
Pagewood build. Last days of July 1968 or into first few days of August would be my estimate.
Its VIN will be close to 80737KH530475 give or take.
Edited by user Saturday, 24 May 2025 7:51:38 AM(UTC)  | Reason: Not specified
Wallsy Offline
#5 Posted : Saturday, 24 May 2025 10:27:26 AM(UTC)
Wallsy
Thanks for the info. Helps tracking down the period correct parts that are now long gone. For refence it's a 307 powerglide car, well purchased under that assumption anyway.
HK1837 Online
#6 Posted : Saturday, 24 May 2025 12:23:19 PM(UTC)
How close was I with the VIN? #382 is a V8 as well. Is yours a banjo or a Salisbury? I think it was from August production that Salisbury became mandatory with V8 auto in GTS
Wallsy Offline
#7 Posted : Saturday, 24 May 2025 3:33:55 PM(UTC)
Wallsy
Pretty close with the Vin, 530522. It has a banjo rear end.
HK1837 Online
#8 Posted : Saturday, 24 May 2025 3:52:27 PM(UTC)
It’s PSN is actually higher than #382, which means yours overtook it in the assembly plant, the VIN tag went on right at the end of the assembly process but the chassis number and Body tag went on in the body plant.. which makes me think 382 might have been a manual.
Wallsy Offline
#9 Posted : Saturday, 24 May 2025 3:58:34 PM(UTC)
Wallsy
The hole in the firewall for the speedo cable gives mine away as being an auto.
HK1837 Online
#10 Posted : Saturday, 24 May 2025 4:21:31 PM(UTC)
Manual has the same speedo cable hole, all V8 HK had the same extra speedo cable hole. I got that back to front above, #382 actually overtook yours. Its body and chassis number are higher than yours (6 x chassis numbers apart) but yours was delayed or 382 was sped up. It is possible 382 was an auto with banjo but yours was Salisbury maybe? Something delayed yours going through the Assembly Plant, it may be something simple like yours had air or steer or salisbury or even its trim was different and they did a batch of the same trim cars together. #382 is 18Y trim.
Wallsy Offline
#11 Posted : Saturday, 24 May 2025 4:53:02 PM(UTC)
Wallsy
Well, that is interesting. Mine is 18Y trim also. Colour is 585-1285. No air or steer that I can see but certainly could have been robbed at some point. I'm sure this was a parts car for something. Definitely a banjo in it and doesn't have the hump in rear floor. Interesting enough it currently has a manual pedal box in it, but I was told that it was swapped out at some stage by someone? The plot thickens.
#12 Posted : Saturday, 24 May 2025 6:32:10 PM(UTC)
Pressing ( or absence of one) on the passenger floor side of tunnel will answer your auto v manual question
Wallsy Offline
#13 Posted : Saturday, 24 May 2025 6:39:30 PM(UTC)
Wallsy
If you are referring to where the shifter comes through the floor, yes, it has that lump where the console needs to allow for it. If anything, else. please elaborate. Happy to learn more about this vehicle.
HK1837 Online
#14 Posted : Saturday, 24 May 2025 8:40:18 PM(UTC)
They have a pressing in the floor/tunnel interface to clear the shifter linkages for a manual. If it’s a banjo car it won’t be a manual though.
Blu253 Offline
#15 Posted : Saturday, 24 May 2025 9:01:02 PM(UTC)
Blu253
Did HK Monaro have 307 with manual ?
Generally only heard “all HK 307 are auto”.
Current daily drivers
VFII Sportwagon SV6; BF Astra RS
In the shed
VH Vacationer Pacific Blue 4.2
HK1837 Online
#16 Posted : Saturday, 24 May 2025 9:51:53 PM(UTC)
All HK was available with 307 manual except for Brougham and GTS327.
Blu253 on 24/05/2025(UTC)
Wallsy Offline
#17 Posted : Sunday, 25 May 2025 7:21:45 AM(UTC)
Wallsy
So what date code and numbering would I be looking for to try to get a period correct engine block?
HK1837 Online
#18 Posted : Sunday, 25 May 2025 7:31:46 AM(UTC)
Just get a Pagewood 307. They are always for sale on Gumtree and Marketplace. Lots went into cars.
Wallsy Offline
#19 Posted : Sunday, 25 May 2025 7:36:45 AM(UTC)
Wallsy
How will I know it's a Pagewood engine? Most people selling them seem to know little about the engine's origin.
HK1837 Online
#20 Posted : Sunday, 25 May 2025 10:39:44 AM(UTC)
Engine number between 30710000 and 30718000. Obviously early HK pre Monaro/Brougham (12/67 to late 6/67) are the early numbers and the later ones will be HT so somewhere in the middle of that range will work, but it doesn't really matter if its not the original. #382 was just over 13000. If you happen to find 30712689 let me know, its the original out of my car, its around as I saw it for sale with a faked blue HK GTS a few years back.
