Joined: 23/05/2025(UTC) Posts: 18 ![Australia Australia]() Location: Brisbane
Originally Posted by: HK1837  Engine number between 30710000 and 30718000. Obviously early HK pre Monaro/Brougham (12/67 to late 6/67) are the early numbers and the later ones will be HT so somewhere in the middle of that range will work, but it doesn't really matter if its not the original. #382 was just over 13000. If you happen to find 30712689 let me know, its the original out of my car, its around as I saw it for sale with a faked blue HK GTS a few years back. Talking to a guy that has an engine with the number 307113** won't disclose the rest of the numbers. That should be in the range hey!
It’ll be out of a May build but close enough. Will have been an auto engine too. |
Originally Posted by: HK1837  It’ll be out of a May build but close enough. Will have been an auto engine too. So much to learn with these cars. Really appreciate all the information and help so far. Really helps getting things period correct at least. Will keep an eye out for that engine of yours too.
It was on a pallet with a blue GTS fake at Lloyds a few years back. The Monaro had a 327 in it but it was claimed to be an original V8 GTS and the engine with it was its original, which it wasn't. It just happened to by my original for Pagewood GTS #20. |
Originally Posted by: HK1837  It was on a pallet with a blue GTS fake at Lloyds a few years back. The Monaro had a 327 in it but it was claimed to be an original V8 GTS and the engine with it was its original, which it wasn't. It just happened to by my original for Pagewood GTS #20. That would have been annoying to see. Ryan who works at Lloyds is a family friend to my wife's side. He has been with them a few years and handles those cars usually give his history with them. He may have an idea of where it ended up going, state wise etc. Worth me asking anyway.
I spoke to them at the time and they wanted way too much for it. They had to buy the GTS back as buyer discovered it bc was faked. |
Joined: 12/01/2025(UTC) Posts: 44 ![Australia Australia]() Location: Macarthur Thanks: 44 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: HK1837  All HK was available with 307 manual except for Brougham and GTS327. Thanks. I had read somewhere that Auto was compulsory with 307 in B/K/P’s. |
Current daily drivers VFII Sportwagon SV6; BF Astra RS In the shed VH Vacationer Pacific Blue 4.2 |
Originally Posted by: Blu253  Originally Posted by: HK1837  All HK was available with 307 manual except for Brougham and GTS327. Thanks. I had read somewhere that Auto was compulsory with 307 in B/K/P’s. 307 V8 were Powerglide only prior to Monaro release (i.e. Jan-July '68). Oncen the Monaro was released the 4-sp Saginaw became available as an option for all HK (V8 or 6-cyl), except Brougham. This "307 V8 Powerglide only" thing was a common myth in the 80s & 90s after a motoring journalist, who should have known better, stated this "fact" in Street Machine & other magazines. Dr Terry Edited by user Tuesday, 27 May 2025 7:25:27 AM(UTC)
| Reason: Spelling |
Originally Posted by: Blu253  Originally Posted by: HK1837  All HK was available with 307 manual except for Brougham and GTS327. Thanks. I had read somewhere that Auto was compulsory with 307 in B/K/P’s. As Dr Terry says. In fact in HK after Monaro/Brougham release if you ordered a V8 car it basically came standard with 4spd, but not quite as per HT onwards. In HK it was Power Train Combinations you ordered, not as per HQ on where you'd tick L31 and if you didn't tick M35 or M40 you got M21. For say a HK Monaro (same price as Belmont and Kingswood models) Retail pricing: L30 plus M35 and G92 (2.78 nodular banjo) or G93 (3.08 nodular banjo) and G80 (LSD) was $510. Console shift added another $30 L30 plus M21 and console and G88 (3.36 LSD Sals) or G89 (3.55 LSD Sals) or G94 (3.08 LSD Sals) was $585. As you see the manual was $45 dearer if you took into account console shift with the auto. This was a rip off in the Monaro as you had to have bucket seats with console shift (powerglide was standard with column shift in Monaro, Belmont and Kingswood). But in Belmont and Kingswood the price has to include include A50 bucket seats which were $50 so it was basically the same price by the time you added that to L30 + M35 + M11 (console shift), actually $5 dearer for the auto. |
Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
Hi Wallsy
Is it a v8 banjo and which type of bracket holds the spare wheel in the boot.
May be the same spec as mine.
Bazza.
Bazza.
Hey Bazza, It's a banjo, not sure how you tell if a v8 or 6 diff, but a banjo nevertheless. As for the spare wheel, it has the bracket that bolts behind the RHS taillight and sort of hugs the wheel really badly.
V8 banjo are a nodular carrier. They use bolts at the bottom whereas the 6cyl centres use studs all the way around. |
Originally Posted by: HK1837  V8 banjo are a nodular carrier. They use bolts at the bottom whereas the 6cyl centres use studs all the way around. Ill check in the light tomorrow and let you know.
Also use V8 uni joints. V8 banjos were 2.78 and 3.08. 6cyl ones were 3.36, 3.55 and 3.90. You'll never find a 6cyl banjo ever in a V8 Holden but you could option a 3.08 V8 banjo in a HK passenger vehicle behind 186 or 186S with M20 or M21 4spd. Torana is different though where the V8 ratios were used in 6cyl cars with 6cyl unis. |
[img]null[/img] Originally Posted by: HK1837  Also use V8 uni joints. V8 banjos were 2.78 and 3.08. 6cyl ones were 3.36, 3.55 and 3.90. You'll never find a 6cyl banjo ever in a V8 Holden but you could option a 3.08 V8 banjo in a HK passenger vehicle behind 186 or 186S with M20 or M21 4spd. Torana is different though where the V8 ratios were used in 6cyl cars with 6cyl unis. Looks to have 3 bolts holding the centre in on each side. The shocks have been robbed out of the car also. I think it's been swapped out too like the rest of the driveline.
Sounds like it had 5 inch rims if it hasn't got the floor mounted bracket.
