Fastlane
Holden Forums
Holden Technical Talk
How to fit a Chev 307 Radiator fitted to 186 engine - Taxi pack?
Hi All,
I am wondering how to fit a Chev 307 Radiator to a 186 engine, running a Powerglide. The car has dealer fitted Repco Cooldrive under dash aircon (works a treat), but things heat up a bit on a hot summer's day and am looking at ways to improve the cooling for the old girl. The engine has a 6 blade fan fitted which was part of the old Repco kit.
I have been told the 6 cylinder cars that came with factory aircon and cars that were ordered with the so called Taxi Pack were set up this way - I don't know if this is correct or not.
I have the 307 auto radiator, shroud and a few other pieces, but I have noticed that the radiator inlet and outlet pipe sizes do not match the standard 186 engine inlet and outlets.
Any advice or know how would be appreciated.
htprem
Thanks: 1 times Was thanked: 561 time(s) in 535 post(s)
You'll have to get the outlet ports changed to 6cyl. I think the top one on a SBC is the same size as the lower one on a 6cyl so you should be able to get that one moved. The other way is to get a HJ to HZ 6cyl HD one and use it. |
Hi HK1837,
Thanks for your advice - so its as simple as changing the inlet and outlet pipes on the radiator I have with the ones from a standard 6 cyl radiator.
Is the HJ-HZ Heavy Duty one the same size as the 307? Am asking as my understanding is that if I remove the spacers on the 6 cyl radiator setup, then the 307 radiator bolts straight in to the 6 cyl car without any modifications to the car body.
Thanks again
htprem
HJ-HZ fit, you just have to drill some holes in the front as the mounting holes are different. It otherwise works OK.
Yes a 307/327 one will fit exactly where a 6cyl one was. The only issue will be the V8 shroud probably wont work with a 6cyl but it will be relatively close - I used to use 6cyl HJ-HZ aircon car shrouds on SBC in HQ-HZ. It might be worth playing around with a viscous fan and the 307 shroud and see how it goes. |
Fastlane
Holden Forums
