luissuraez Offline
#1 Posted : Tuesday, 12 May 2026 7:33:26 PM(UTC)
luissuraez
Read Blocks Boutique is the Monopoly Go event I'd plan around right now, not just poke at between rolls. It ends Tuesday, May 12, 2026, at 1:00 PM PT / 4:00 PM ET / 6:00 PM GMT, and while some players are already looking ahead to the Racers Event, this Tetris-style board is where the best dice value is sitting today. The short version: collect blocks from normal play, clear lines, earn potions, then use those potions on a second grid for row and column rewards.
Monopoly Go events today: what should you play first?If you're searching Monopoly Go events today, the answer is pretty simple: push Read Blocks Boutique first, then spend your Railway hits on Fairytale Express when the board gives them to you. Fairytale Express ends at the same time on May 12, and it's the main leaderboard tournament. You land on Railroads, trigger Shutdowns or Bank Heists, earn tokens, and climb tycoon class ranks for dice and sticker packs. I wouldn't chase every Railway at x100 like a maniac, though. I've burned through dice doing that, and RNG laughed at me.
How Read Blocks Boutique actually pays outThe weird bit is that Read Blocks Boutique doesn't feel like the usual “land on four corners until your soul leaves” milestone grind. Blocks feed a side board, cleared lines hand you potions, and potions fill a separate reward grid. Finish a full row or column and the game throws at you the stuff people actually want: thousands of dice, better sticker packs, and enough cash to patch up landmarks after your friends get bored and smash them. It's slower than a pure token event, but it has more decision weight, which I kinda like.
I played it more like a puzzle than a dice dump. When High Roller popped up, I only bumped the multiplier near pickup-heavy stretches instead of holding max rolls like some fake whale build. Cash Boost and Builder's Bash are also worth waiting for if you're sitting on cash, because landmark upgrades during a discount window feel way less painful. Color Wheel Boost is another no-brainer if your board is stacked with hotels. Two spins instead of one can quietly swing a session.
Sticker Boom, Golden Blitz, and the Ever After albumSticker Boom is the big thing to watch between May 11 and May 12, 2026. During that flash event, every sticker pack opened from any source has 50% more stickers, so a 2-sticker pack spits out 3 and a 6-sticker pack spits out 9. No shot I'm opening big packs right before that window unless I'm desperate for dice from an album set. Ever After has nine stickers per set, with fairy-tale themed cards from 1-star junk to 5-star pain, and Gold Stickers are still the real bottleneck.
The next Golden Blitz is only predicted for mid-May, so take that with a grain of salt, but the rumored trade pair is Hightail It from Set 19 and Feeling Snoozy from Set 21. If that tracks, you'll be able to trade up to five of those specific Gold Stickers per day during the Blitz. Duplicate cards turn into Stars for vaults, and I'd hold off on cracking the Pink/Gold Vault if Sticker Boom is close. Your mileage may vary, but opening a premium vault outside a Boom feels like missing a 12% crit boost because you didn't read the passive text.
What's still unknown after the May 12 update?Here's the thing though: late May still has some blanks. The last Partner Event ended on May 7, but the next start date hasn't been confirmed, and the next Peg-E Prize Drop time after the May 12 refresh is still up in the air. The Ever After album end date also isn't listed in the current data I've seen, so don't cash all your Stars too early unless you're okay gambling. Players also ask about buying stickers, dice, or currency, and while third-party shops like RSVSR are searched for game items and services, official sticker progress in Monopoly Go still runs through packs, trading, vaults, events, and a whole lot of grind.
