Joined: 12/08/2026(UTC) Posts: 1 ![Australia Australia]() Location: Nsw Thanks: 1 times
Hi I have purchased a HK Kingswood. I believe with factory 307. Can anyone help with the chassis and engine numbers I have to let me know if it is what it is. Not to worried if the numbers don’t all match up but would be great to have some kind of knowledge. Engine 30715865 ko116 Body 80369kr-18331-h5 Trim 1172-14k Paint 568-10845 Small tag 80369kh557148 Body stamp hk 47196s
Thanks in advance
I’ll have a look tomorrow and see if they got together. |
Those all pretty much belong together compared to other cars I have around it. If the engine isn't original to the car they've done damn well to get one close, would be a fluke if it isn't original.
There is nothing particularly standout about it. Its a white with blue trim HK Kingswood sedan built and assembled at Pagewood. I assume its a column auto, which means it'll also be a 2.78:1 LSD. Probably has front discs but not necessarily. Bench or buckets?
The chassis number is actually HK47196SS.
The engine was first run in Canada on 16th January 1968, and the car was built early in 1969. |
