68 HK Offline
#1 Posted : Saturday, 12 September 2026 11:01:47 AM(UTC)
68 HK
Hi all
first time posting
have purchased a brand new set of HS6 triple su for my 68 hk premier running 186s what modifications do I need to do to get them fitted and what parts etc will need .
any info would be great .
#2 Posted : Saturday, 12 September 2026 2:34:07 PM(UTC)
Was thanked: 628 time(s) in 591 post(s)
Not something I can help you with. Most people turf a 6cyl and fit a V8 for more performance in a HK. Somewhere like gmh-torana might have more info as this sort of stuff is normally done by the LC-LJ crowd.
68 HK on 13/09/2026(UTC)
#3 Posted : Saturday, 12 September 2026 9:07:32 PM(UTC)
Most of the bits you will need are available off the shelf, however you will need to custom build some parts.
The best advice I can give is to use good quality parts. Things like fuel hose & fittings & accelerator linkage.
With the linkage make sure you use hexagon shaft & not the cheaper round variety.
If you talk to guys that have lived with triple SUs, they will tell you linkage was the biggest pain in the a*se & keeping the carbies synchronised at low speeds is the hard part.
#4 Posted : Sunday, 13 September 2026 8:09:43 AM(UTC)
Strange how Holden tried multiple carbs on the red motors but never ran anything but a single on their V8’s. Quadrajet was as wild as they went.
#5 Posted : Sunday, 13 September 2026 10:50:20 AM(UTC)
GMH never needed to use anything other than a Quadrajet. The 327 and 350 used in HK-HQ were the lowest power output 4BBL engines of their kind and the Quadrajet was the absolute best carburetor that GM had for street use. The 308 was breathless as it was with the little 253 cam in it. Upcoming emissions arrival from September 1973 meant even triple carbs on 6cyl were finished, that is the main reason XU1 ended at that time.
