Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
Hi guys Trying to work out the type of brake booster on a vc Brock. Is it a single or dual diaphragm
Joined: 6/07/2019(UTC) Posts: 467 ![Australia Australia]() Location: bayside Melbourne Thanks: 301 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: holden05  Hi guys Trying to work out the type of brake booster on a vc Brock. Is it a single or dual diaphragm VC Brocks used the standard GMH 4 wheel disk brake system which had tandem (dual) diaphragm booster HTH |
Copy. The brakes are doing my head in I’ve bled what I reckon is all the air out of the master, pretty much a bottle per corner. The pedal feel i get is good, not soft, good travel Thinking it may of been the booster, I’ve done the test where I turn the car off, pump up the pedal till it’s firm then turn car on. Pedal sinks about 5cm Issue I’m having is the feedback is crap, I’m having to bury the foot to stop and the brakes feel really “wooden Is this as good as it gets or have I a problem? Car has been in storage for a while so would it be pads?
