Ronnoco Offline
#1 Posted : Tuesday, 27 October 2026 10:15:08 PM(UTC)
Ronnoco
Hi All,
I’ve got a 1977 Holden Kingswood Windowless Panel Van with all matching numbers, original motor & chassis (as per compliance plates & HHS report).
Someone mentioned that the rear teeth on the full length hoodlining maybe off a HJ Van, not a HZ.
Does anyone know if Holden changed the type of teeth on the rear strip please?
I have a photo of mine but can’t attach it to this post.
#2 Posted : Wednesday, 28 October 2026 6:10:58 AM(UTC)
The side strips changed between HJ and HX but I never knew about the rear teeth/fingers. I guess GMH might have learned from the body plant fitters that tweaks were made, given in HJ the volume of headlinings was small limited to Sandman and the few amount of other vans optioned with it. HX there was a lot more vans with the longer headlining.
Ronnoco on 28/10/2026(UTC)
This page was generated in 0.017 seconds.
