#1 Posted : Friday, 14 January 2005 8:37:12 PM(UTC)
I have a VN Exec. Driving on the highway the engine just stops, I am running on LPG at the time. Has anybody had this happen to them? If so, any ideas how to fix the problem.
#2 Posted : Saturday, 15 January 2005 12:42:40 AM(UTC)
Is it an intermittant fault? If so sounds more electrical than fuel related. Otherwise if it's all the time is the system leaking anywhere? Lastly the gas converters do expire after a while, usually run very lean prior to dying all together!
Pete
#3 Posted : Saturday, 15 January 2005 1:17:50 AM(UTC)
Mine used to do this. Could smell gas when it happened.
I took it to a gas place, the looked under the bonnet and filled the radiator with water. Never happened again. Seems the converter was freezing up. I looked like a total wank, but at least
