#1 Posted : Tuesday, 18 January 2005 7:42:50 PM(UTC)
I have fitted the SLE cluster to my VH (not origanlly an SLE), and i am wiring up the oil pressure gauge to my 308. The Plug on the back of the cluster has 2 fittings. I know that 1 plug is for the sender on the oil pump. What is the other plug for? Or should only 1 wire run from the back of this plug?
#2 Posted : Wednesday, 19 January 2005 4:04:01 AM(UTC)
Im not sure exactly which one you mean, im trying to go by memory but there is the two plugs that are like 90 degrees to each other or sort of like an L shape ?
If thats the part you mean the the vertical one is for the tacho.
#3 Posted : Wednesday, 19 January 2005 4:43:15 AM(UTC)
thanks.. yes its an L shape. Luckily i labeled the wires horizontal and vertical b4 i put the cluster back in
#4 Posted : Sunday, 13 February 2005 7:38:53 AM(UTC)
one terminal is from sender other is ign switched power
