I have a friend with a HG Brougham, and he needs a new rear lower panel and a rust replacement RH Quarter panel lower section fitted.
Question is. Does the Rare Spares back panel for HG Sedan fit, as in the same as a Brougham? Is a Brougham lower rear panel the same as a regular sedan?
The quarter panel I know is longer. Has anyone come across fitting this before? Is it a case of fitting the sedan replacement lower section as much as possible and fabricating the last bit at the back where the back panel meets?
I can fabricating panels, and I can do the job to a metal finish, but it is worth my time to buy a pre formed panel if available rather than make a whole new one. |
The lower rear quarter differs across HK-HG bodies in diffeent shapes. I havent nailed yet what is what, but I know Kingswood sedan and Monaro in HK are the same. Have a look at the body line that starts around the lower area of the bar and goes forward t |
