#1 Posted : Saturday, 29 January 2005 8:17:27 AM(UTC)
I was wondering if anyone has done this setup, I have installed VP Commodore disc brakes to the front of my HQ using a Castlemaine Rodshop kit would it be possible to use a Commodore rack and pinion
instead of the original HQ steering box.
#2 Posted : Saturday, 29 January 2005 5:40:33 PM(UTC)
It can be done, but there is a bit of mucking around, and you need to weld in brackets.
You may also need to alter the sump for clearance.
Also need to fit a commodore steering shaft as you need the half shaft to get the angle from the firewall to the s
#3 Posted : Sunday, 30 January 2005 4:12:42 AM(UTC)
Thanks for the assistance
