#1 Posted : Tuesday, 1 February 2005 6:47:32 AM(UTC)
Dear Sir or Madam,
Thanks for your attention on brake parts and brake safe problem in advance. We send you this Email for business chance with your esteemed company. Hope not trouble for you. Thanks.
Hengwei Rubber Products Co.,Ltd, is one famous manufacturer of brake series parts including brake and clutch hose, brake hose and pipe end fittings and accessories, brake hose assembly and cylinder etc in China.
Our main products including below:
A. CLUTCH and BRAKE HOSE SAE J1401 1/8”, 3/16”
Producing standard: SAE J1401, DOT FMVSS 106, DIN ISO3996 etc. Our brake hose can be used on any hydraulic brake system of car, motorcycle, scooter, ATV, snowmobiles, forklift, light truck and three wheeler etc.
HOSE 1. 3.2mmx10.5mm 1/8" HL SAE J1401 (two layer white rayon reinforced).
HOSE 2. 3.2mmx10.5mm 1/8" HL SAE J1401 (two layer red and one layer white rayon).
HOSE 3. 3.2mmx10.5mm 1/8" HL SAE J1401 (three layer red rayon reinforced).
HOSE 4. 3.2mmx12.5mm SAE J1401
HOSE 5. 4.8mmx12.5mm SAE J1401
B.FITTINGS AND ACCESSORIES.
We have many type of fittings like male, female, banjo fittings with different angle like 84 or 90 degree and screw like 10x1mm, 3/8x24mm etc. And adaptors, nuts, banjo bolt, washer, clip, rubber sleeve, spring etc accessories used for stainless steel brake hose, brake and fuel pipe, brake and clutch hose, or fittings. We have very strong ability to develop fittings and accessories according to customers’ samples or drawings.
C. BRAKE/CLUTCH HOSE ASSEMBLY.
We have supplied our brake/clutch hose, fittings and accessories and hose assembly for LPR, Wagner, ATE, Delphi etc famous aftermarket and OEM companies.
Our most advantage in brake hose assembly is produce exact and quality goods according to customers’ samples or drawings. We have developed more than 500 kinds of hose assembly for our coustomers.
D. BRAKE CYLINDER (according to samples)
Brake master cylinder; brake wheel cylinder, clutch master cylinder, clutch wheel cylinder etc
Our brake parts have been exported to UAE, Iran, Israel, France, UK, Italy, Germany, Hungary, Lithuania, USA, Venezuela, Australia, etc 31 countries.
If you need brake and clutch hose etc. Ours will be your best choice. YOU CAN NOT GET ANYWHERE ELSE for so good quality, so competitive price and so steady safe BRAKE PARTS.
More details about us and products, pls reference our website www.autobrakehose.com
Best regards,
Ms.Sally
Sales manager
HENGWEI RUBBER PRODUCTS CO.,LTD
EMAIL: [email protected]; [email protected]
MSN: [email protected]
This page was generated in 0.066 seconds.
